A55 Smoothing Plane
Router
Router
Router
Dwight Hohweiler
>I will be milling several 3/4 X 3/4 box joints in oak,walnut&hard maple. What size router do I need & is PC a good brand? Would like a 1/4 & 1/2 collet.
Re: Router
Re: Router
del schisler
>their are a few good routers out their I have 2 porter cable PC690 and 3 others the pc690 has slow start and has adjustable speed control They have the 1/4 and 1/2 collet's For the money they do a good job
Re: Router
Re: Router
Larry Clinton At Frankfort (Central)., Indiana
>I agree with Del. About any decent router will drive a 3/4 bit without a problem. In my opinion the Porter Cable routers are among the best. I would stay away from the Skil, Craftsman, Black & Decker type routers as many have problems with holding depth, durability issues and in general are not a good buy for serious hobbiest or Pro use. I have both the large PC 7539, 3 1/4 HP Speedmatic, mounted in my router table, and a PC 790 set with plunge and fixed bases. If you are planning to use the router for other projects in the future, the Plunge and fixed base combo is a good buy. The set comes with both 1/2 and 1/4 collets. Not saying you should buy from Amazon but this is a link to the PC set with variable speed. http://www.amazon.com/Porter-Cable-694VK-Horsepower-Plunge-Variable/dp/B00009OYFG/sr=1-97/qid=1171895118/ref=sr_1_97/105-7723737-3330848?ie=UTF8&s=hi
Re: Router
Re: Router
>Good Morning Dwight,
I have the P+C 690 and frequently borrow my son's machine when I need two of them, say on a dovetail project. They are rock-solid and a tried and true design. You may also want to consider an inexpensive shop-made box joint jig for your table saw. Most of my box joints were done that way, adapting my dado sled.
George
