OT: Transferring dig video to computer-->DVD
Dominic Greco in Richboro PA
>Hi everyone,
Ever feel like a complete moron when dealing with an electronic device? Well I do right now! :>(
I have a Canon ZR200 Digital Video Camera and have installed all the software necessary to connect this baby to my computer. My intent is to transfer the video recorded on mini-cassette to my computer so that it can then be burned onto a DVD. The software install went without a hitch. I'm able to bring up the ZoomBrowser Ex software with no problems.
So far, I've gotten no where fast with this $&#* camera! My computer refuses to connect to it and I have yet to figure out how to transfer movies from mini-cassette to my computer. I have a feeling that I'm missing something. After reading the directions, I have a sinking feeling that only videos shot onto digital media (aka: a memory card) will transfer. But I'm not sure about this.
If you look on Amazon.com and search for this camera it says:
"Bring Your Analog Memories Into The World Of Digital
Once you own a ZR-series digital camcorder, an entire world of movie and still-image making possibilities opens up as a result of its MiniDV format (a worldwide industry standard). But what about those older analog videotape memories? Canon makes updating them to digital a breeze with its advanced analog/digital converter technology.
Simply connect your TV or VCR to the ZR camcorder's analog line-in/converter and record every priceless moment directly to DV tape. You can even convert the analog signal into a digital signal for direct transfer to digital video devices or computers equipped with an IEEE1394 terminal (the analog-to-digital converter may not function depending on the software used).
It's all thanks to Canon's exclusive connection circuit, called VIC. VIC is a virtual powerhouse. Traditionally, multiple chips were needed to perform the camcorder's input and output functions. VIC manages it all with one single chip. The result is seamless connectivity whether you are connecting to a computer, TV, or VCR. "
The above statement leads me to believe that I CAN accomplish what I want. It's just that the software manual and web site are so cryptic that they drive me NUTS!
So,...does anyone have an idea what to do here? Have any users of this camera done what I want to do?
Thanks in advance.
See ya around,
Dominic
Re: OT: Transferring dig video to computer-->DVD
Bob Persing
>Dominic,
Have faith, I'm sure it can be done but maybe not with the software you now have. Are you using the 1394 connection from the camera to your computer? (1394, als refered to as Firewire...Apple Computer's proprietary name for IEEE standard). The info you posted seems to indicate the 1394 connection should be used to transfer the digital info from the camera to the computer.
The blurb you posted did indicate that it might not work depending upon the software used. It is not clear how much may or may not work but I know this CAN be done using software from outfits such as Pinnacle and Ulead.
Sorry, I can't offer specific info but I have done similar tasks with other folks computers and have been looking into buying a video capture add-on for my PC. Pinnacle and ADC have been the brands I have seen in the stores...they come bundled with the software needed to make the DVD from a digital camera input or from an analog source such as a VCR. It sounds like YOUR Canon camera has this funtionality built in...koool.
Hope someone else can provide specific info about the Canon supplied software.
BobP Skillman, NJ
Falberg saw Co
>I don't know if this will help, but I use a Sony camera whose driver connects it to my computer probably the same as yours. The camera's software doesn't save it for digital editing, however, and I have to use Windows Movie Maker to record the streaming video. If that's your case - you need to connect the camera, turn it on, and then open Movie Maker (it's free with Windows) . From the Movie Maker "Task Pane" you select "Capture from video device" at the top. The video streaming from your cassette should now be visible, with sound, on the Movie Maker screen.
For me there was a long learning curve to using Movie Maker ; but once you get it , it's pretty powerful software and you can do some cool tricks. If you don't have a big, fast computer it can take forever to process even short two minute videos so you gots to be very patient.
After you've saved it to your desktop you can save it in DVD, if you have a DVD burner.
Drat! Movie maker for XP only
>You wrote:
"however, and I have to use Windows Movie Maker to record the streaming video. "
If you read the title of this response, then you know. Movie maker is for XP only! I went to MicroSoft's site and looked up the details. It has no link for a Win2K version. Drat!
Thanks anyway!
See ya around,
Dominic
Supplied USB cable
>Bob,
You wrote:
"Are you using the 1394 connection from the camera to your computer? (1394, als refered to as Firewire...Apple Computer's proprietary name for IEEE standard)"
I'm using the supplied USB cable. But I think there is another cable called the "DV" cable that is required. This could be the one you're talking about. On page 77 of the manual, under the heading "Recording to a VCR or Digital Video Device" it calls out a "commercially available DV cable". This leads me to believe that the supplied USB cable is for downloading images from the memory card ONLY.
Thanks for the advice.
Dominic
Re: OT: Nero
Chuck W
>Dominic,
If you are using Nero then it should be possible to capture the video from your camera. I just check mine and it has that feature in Nero Vision 4. Its called "capture video to hard drive".
Re: Supplied USB cable
Steve Kirincich
>Your problems are similar to my experiences with my Panasonic digital camera. The USB cable will most likely be useful for transfering still pictures stored on the memory card. You will need a firewire cable for the video transfers. Make sure you get the right size firewire cable. When connecting my camera to my laptop, both ends of the firewire cable need to be four pin jacks. When connecting to my desktop computer, I need a cable that has a six pin jack for the desktop and a four pin jack on the other end (of the cable).
Tom
>You're right. USB is for photos only. I've got that camcorder. Don't waste your time on photos. Buy a 4 pin to 6 pin firewire cable, assuming you have a firewire card in your pc. If not, buy one that comes with a cable (and software, like Ulead, by the way). Newegg or Acortech is a good place to start. TI chipsets are good. I've never had a problem with a TI chipset card. XP will recognise it and install native drivers. I think 2K will too. You can then capture from within your video editing software. Capture as .avi (or dv), and then use a third party software to encode, like Tmpgenc. Nero, Ulead, and Roxio encoding leaves a little to be desired in terms of speed and quality. Use the aforementioned to author a dvd, not encode if you can help it.
Thanks everyone!
Dominic Greco
>Thanks for all the responses. Looks like I'll be shopping for a firewire card and cable to add to my PC.
Thanks again,
Dominic
