How dry is dry
Roger
>How dry should wood be before you use it to build with?
How dry is dry
Roger
Depends |;-}}
Re: PS
>Take your moisture meter and test your wook bench and the door jamb of your shop. They should be equal MC. When your stock matches that reading you're good to go.
mm
Re: How dry is dry
>As Mark said, that depends. Wet wood doesn't glue well :). I've also had some wood assume "interesting" shapes when I've cut it and it wasn't completely dry.
commercial recommendation
bill tindal, E.TN
>Furniture factories specify 7% moisture content. It is judged that this level is about midrange for what furniture will experience. On the other hand without humidity control one builds with what one has and designs to accomodate change. You will have less problems starting with lumber too dry than lumber too wet. I would be concerned with lumber over 10%.
Re: Dry
>Roger,
The basic concept here is that the stock you use should be at EMC, Equalized Moisture Content. That value will change "depending" on where and when you are. EMC here in my corner of NJ varies from 9% in the Winter to 12% in the Summer. Values for Arizona, Florida, and Alaska will be different at any given time. Thus the other "stabilized" wood around you will give you the best indicater because all of the wood "in service" in a given location will be at the same EMC, regardless of species. Just remember however, that "dry" is not enough to insure structural integrity. You still must build your piece with the inevitable changes in EMC and resulting expansion and contraction in mind.
mm
