OT: Calling All PC Gurus - Hard Drive Question
Robert Hutchins
>I'm getting a sound from my primary hard drive that probably means it might be about to go. I am making a new backup to an external USB drive as I type - just to be sure. I have 2 other hd's in the system. The one thats making noise has the WinXP/Pro os and a lot of data.
First, can I just copy the os directory to another drive - changing the slave/master switches, of course, or do I have to do a fresh install? If so, are there any precautions/rules/gotchas? If I can't just copy the os directory to a different device, why not? I have tons of software that would have to be reinstalled if I have to do a fresh XP install. Prolly take a couple of days to get things back where they are now.
Second, what strategies do you guys use to avoid banging the heck out of just one of your drives? I'm thinking of buying the optimum size drive to hold just the os - since it gets hit most often, doesn't it? All of the drives that I have are over 200GB. That's a lot of eggs in those baskets. Wouldn't a small RAID 5 set up on an old system make more sense? What would a fellow have to do to make that happen? How much horsepower (RAM, CPU speed) would the RAID server need? What would the optimum size for HDs in a RAID be? Seems that 100's of GB per drive might be wasteful and that something on the order of 80GB per hd would be cheaper. Would it be feasible to share the RAID with HL's system over a wireless network - too slow, any other reasons not to do it (assuming a WPA-secured setup)?
Got any more tricks up your sleeves? Would really like to hear from you gurus.
TIA
