I have an alaskan mill
Mike in Paradise
>The 390 is a plastic CrankCase saw not really designed for milling.
Go over to Arboristsite and look for the first post from a user name CoverInSap and see his bad experiences with the MS390 and milling...(Plus he ends up in a big fight with the site and gets banned after a few months, off topic but entertaining)
http://www.arboristsite.com/showthread.php?t=31315
With an Alaskan mill you will lose about 4 inches off of the bar size of your chain saw with the area that attaches the mill to the saw. Eg 36" bar = 32 inch cut max. Your 20 inch bar will only give you a 16 inch cut.
There is nothing special about the milling bars. The ripping chain will give you a smoother cut but I have milled with a regular chain with no problem when I have forgotten to bring a ripping chain with me (The wood in the picture was done with a standard chain).
You can get the ripping chain from Baileys-online for about 23 cents a link.
You also need something to start the first cut on and I use my aluminum ladder for that.
You did not say what you want to do with the burl wood and what size of pieces you would like to keep or how hard the wood is.
Your MS390 will struggle with a really large bar required to tackle that size of burl if you are going for larger width pieces.
I have a Stihl MS660 that I use in my Alaskan Mill and I would not want to use a saw much smaller for other than occasional use.
Milling is very hard on a chainsaw as you are running them wide open for a much longer time than they usually run.
Milling is very hard on you as well as it is physically demanding hard dirty work that is also very satisfying.
