Contractors table saw dust hood
Chuck Lenz
Chuck Lenz
Re: 10" x 10"
Chuck Lenz
Re: 12" x 12"
Chuck Lenz
Re: Contractors table saw dust hood plans
Chuck Lenz
>If anyone has a problem with being able to read the dimensions on the blueprints, just e:mail me and I'll send you a larger, more clear copy.
I See an Email to You from David Yoho
Robert Hutchins
>in my crystal ball. He'll want to make a ShopShot out of that FOR SURE!
Thanks for the pics, Chuck!
Re: I See an Email to You from David Yoho
Chuck Lenz
>Anytime Robert, thankyou for the compliment.
Email sent - Thanks Bob
David Yoho
Phileas
>Great idea, and very well executed.
I'm confused a little bit though. Don't you have to seal or at least block the back? Or you lose almost all of the suction and dust blows out the back?
Regardless, I'm building one.
Thanks,
Phileas
Chuck Lenz
>Hi Phileas, I'm still pondering on the thought of closeing off the backside of the saw, but I haven't seen a design that I'm totally happy with and for what little does escape out the back if any, I'm not sure it's worth it for me. I know I will never get all the dust with any machine. When I designed this hood I wanted something that was easier to hook a collection hose too than the generic plastic hood that I was useing. So then I tried a heat register boot that had about a 2 1/2" x 10 opening aligned so it was parallel under the saw blade and the 4" port pointed out the back of the saw. It worked ok until I tilted the blade and the blade was no longer above the opening. So thats when I came up with this design. It is hooked up to a 1300 CFM dust collector. When you build one I'd be interested to hear your thoughts.
ray k.
>Nice work! My quick and definitely amateur solution was to use some mis-matched scraps of 1/4 plywood custom cut to size using my scrollsaw. It doesn't look pretty, but it took only a few minutes. To secure the cover in place, I epoxied rare earth magnets in recessed openings in the plywood. The cover works great and as an added bonus, should you forget to remove the cover when you're tipping your sawblade, the cover will just pop off. There's no need to bolt anything down. AGain, not pretty, but it works and it didnt' take up too much shop time to make.
ray k.
