Unisaw bearing replacement
Paul Blackwell
>My new bearings arrived the other day, and I read the article by Bill Tindall detailing step by step how to replace them. He said he put the arbor in the freezer for a couple of hours, and heated the bearing to 100 degrees. I can see that freezing the arbor would cause it to shrink, but I'm having trouble getting my mind around heating the bearing to make the bearing hole larger. It doesn't seem to me that the expansion is unidirectional (outward). Wouldn't expansion of the metal cause the OD to increase and the ID (hole) to become smaller? At any rate, I tried following the directions, froze the arbor and tried gently slipping the bearing onto the threaded end of the arbor. As soon as the bearing slipped past the threads, it became wedged so tight I'll have to press it off the arbor. It seems to me that freezing the bearing would cause the hole to become larger. Any suggestions greatly appreciated.
