OT- Windows XP Netscape question
Lee Schierer - McKean, PA
>I use netscape 8.1.2 as my browse on my new WIndows XP computer. We just got this computer in December and until this week everything worked fine. Every few minutes when we are on the internet the computer will freeze and you can't do anything. The task manager says netscape is using 99% of the CPU. If you click on teh screen during a freeze, teh screen will go white except for a blue bar across the top and the start bar at the bottom of the screen. After a bit, the computer will come back and you can go on with what you were doing until it freezes again. These freeze periods last about a minute, then the screen will come back. Just while typing this the computer has "frozen" four times. If I don't notice the freeze right away while I'm typing, it seems to remember what I was typing and it will appear on the screen after the freeze is done. The modem activity lights do not appear to indicate that the computer is accessing the internet during the freezes.
I've attached a screen print of the task manager to show what is running. Any ideas?
Lee
Re: OT- Windows XP Netscape question
Chuck W
>Does your computer freeze while using other browsers? When did the computer begin to freeze? If you can pin down when the problem began you may link it to some software that you added.
Simple Fix
Ron in Drums PA
>FireFox
Robert Hutchins
>Howdy Lee,
Do you allow automatic Microrot updates? They had a bunch of security updates out this past week. It's (remotely) possible that one of them created a problem with Netscape.
I went to Firefox several years ago and use it for everything but updates from Redmund (they force you to use IE). I've never had a problem with the browser, whereas IE used to freeze, crash or just quit very frequently.
Don't know anything about Netscape.
Jerry Nicholson
>Did Microsoft Update try to install IE 7? That screwed up IE and NAV for a friend. He had 256 mb RAM and the original release of XP. I had to do a non destructive reinstall of Windows XP. I increased his RAM to 512mb, updated XP to SP2, turned automatic updates OFF, and downloaded the security updates specifically telling Windows Update NOT to install IE 7 and don't bother us with it again. I also installed trial version of Kaspersky antivirus and Firefox 2.0. I left him with instructions to run Windows update manually every few weeks using the Custom option and NEVER let it install IE7.
I have had similar problems with Norton Antivirus updates. Norton can screw up your computer when it updates its program files. I run Norton Live Update manually and aloow update of virus signatures only.
Try a restoring back to a point prior to the start of the problem and see if that help. Restore will not, however, repair corrupt program files.
Jerry
Bob Fawcett
>Chuck,
You have 5 instances of svchost.exe that I can see. Those indicate a lot of connections for something. Are you running something else that is making a background connection? It could also indicate some sort of malware or spyware. Check for viruses and spyware.
Howard Acheson
>Both my Dell Laptop and my Dell Desktop started doing the same thing in the past few days. I run Windows XP. There are others who are reporting the same thing. I have to Control-Alt-Delete to get out of it and it reports 100% CPU usage.
I run current, up to date virus and malware software which scan both my computers every night.
I am wondering if some recent automatic Windows update is causing the problem.
Here's the problem and a fix *LINK*
Alan in Little Washington (NC)
>The problem is country-wide- NS built in a behind the scenes reporting function in NS 8 series. It reports to a NS website which, unfortunately has been down now since about Feb 14 and they didn't incorportate a time out feature to the reporting so it hangs up your computer for a minute or so, unfreezes, then starts over. As a temp fix you need to disable the reporting function. You'll still notice a momentary ( < 1 sec) hiccup, but it won't freeze up any more.
Follow the link below to see the detailed instructions I used to temporarily fix the problem. If the link doesn't work or if you want to read more about it go to Netscape "Help" at the top of the screen, Help & Support Center" "Community" "Message Boards" "Technical Issues" and go to page 6 of the "8.1.2 Locking Up" thread (message 101 of 123).
NS 8.1.2 Temp fix
Re: Here's the problem and a fix
Ray SW Ohio
>I would be a little concerned about what Netscape is sending back to their server.
Kirk (KC) Constable
>Hmmm... it woulda been a lot more fun to find a way to blame Microsoft. :-)
KC
I Tried To
Robert Hutchins
Agree ;-)
Dan Donaldson
windows updates *LINK*
Curt Harms
>Hi Bob
Actually, You don't HAVE to use the MS windows updater. I use 62nds.com in Firefox with Win2K and it seems fine. I have heard the updates are slower by a few days than MS crap, but as long as my antivirus & firewall are up to date, I'm not too concerned. I do stay away from P2P and naughty sites. You do have to be logged on with administrative privileges in order for the FireFox plugin to work.
FireFox windows updater
Howard Acheson
>As I recall, you are given the option of participating in the reporting scheme at the time of original set up. I opted in at the time. I guess if you uninstalled, then reinstalled and opted out, you should be OK.
Once Again I Prove What an Idiot I AM
Robert Hutchins
>Howdy Curt !
Thanks for the tip, but I couldn't find anything on the 62nds site. Is there a specific extension that you use for Firefox that allows you to use it for accessing microsoft.com's windows update and office update sites?
TIA
BobH
Follow up! *LINK*
>This seems to be a global problem with netscape 8.1 and higher. It started about Feb 15. Your computer will experience 100% CPU usage for a minute every other minute so you can't do much. The fix for now seems to be to edit the host file, which I did and the problem has been resolved for the moment.
Here's the text from the solution:
"Have edited my hosts file to look as follows and the hang up has gone.
127.0.0.1 localhost
127.0.0.1 ns8-stats.netscape.com
Hosts file can be found:
1. Use notepad and edit the hosts file in the windows directory. Ex.
C:\windows\system32\drivers\etc\hosts ."
Lee
Netscape Fix
Jerry Nicholson
>That's why I continue to use ZoneAlarm as a firewall rather than the XP firewall - I can stop these programs from calling home and reporting whatever it is that the vendor thinks should be reported. Many programs try to call home, including Firefox and Nero and all kinds of Microsoft stuff.
I have never used Netscape so I don't know anything about it.
Jerry
