I had sanded a bunch of southern yellow pine on my drum sander that badly clogged a couple of sanding strips. I soaked them for weeks in my mineral spirits parts washing tank and it had no affect on the pitch buildup on the strips and I ended up throwing them out.
Maybe something other than mineral spirits would work better.
>I had a belt that was gummed up from some cruddy pine boards I cleaned up. I don't use my proformax as much as I use to. It sat for over a year before I wheeled it out for some segmented turning I was doing. This belt soaked for about two years in Simply Green.
Recently I discovered this jar and figured "What the heck, I see if it still works" It didn't hurt the belt and did a really good job removing the pitch.
So your answer to your question "How long should I soak it" is "Somewhere between 15 minutes and two years should be good"
As mentioned in Mark's thread, I had some "stuff" that the deturgent wouldn't touch even after a 2-day soak. Easy-off applied to the abrasive busted it off with 2 applications and a brush after which I washed the belt well with the soak water and a brush and then rinsed very well.
I tore the end off a belt, and ended up just using some strapping tape to hold that end of the belt on the drum. Worked great, though, you want to make sure that you do not sand all the way out to the tape.
>Lye is caustic soda, and there is a drain cleaner which is sold in the grocery stores by the trade name Red Devil drain cleaner. It is cheap.
If you have an empty paint pail, you can mix a few table spoons in about a gallon of water, and just keep it in there in a safe place, and just keep using it over and over. It will clean really burned on pitch on saw blades, I am sure it would do belts as well.
I made a dasher like a churn to slide the blades onto, which makes retrieving them easier. About five minutes is all it takes to soften the pitch on a saw blade. I have never tried a sanding belt in it, so I don't know if it will act on the seam.
You do need to be careful not to splash any on yourself, it will burn a hole in your clothes, and may blister you skin.
Although lately, for cleaning saw-blades, I tried a little 2" diameter cup wire brush wheel in a power drill to clean the blades, and I think it is faster and easier, with no mess. Just lay the blade on the bench-top and run the drill so-that the wheel contacts the saw plate first, and runs out toward the tooth at about 45� from the back of the tooth. this will keep the sharp edge of the tooth from eating the wire brush. this only takes about a minute.
>I gauls me to pay $8 for a strip of sand paper to use on the Performax and have it go bad (gummed up) after sanding six or seven linear feet of pine. I know its heart pine and full of resin, and I knew this was going to happen, but still, seven feet? Thats more than a buck a foot.
So, I'm glad to be finding ways to clean them. Bless my frugal little heart. And thanks guy for supporting my pack rat stingy habits.
The ones that were not burned in cleaned up pretty nicely. Now I have one with glue and I will try vinegar. Just have to be careful not to get more time and money into this than the belts are worth. Thanks again.
