OT: How long to change an oil pan gasket
Kerry Adams
>Hi,
How long should it take to change an oil pan gasket on an 1997 Buick LeSabre. Is 130.00 labor too much?
Thanks,
Kerry
Re: OT: How long to change an oil pan gasket
Jim Shaver Oakville, Ont.
>Hi Kerry,
Depends on how much work is required to get to the pan, some times they need to move steering components to get at the area. I am not familiar with a 97 LeSabre (I had a 68), but at $80+ an hour around here that sounds about right given what is required.
Take care,
Jim
Don't quibble over pennies...
Jason Roehl in Mulberry, IN
>With shop rates anywhere from $60/hr on up, getting out of a repair for less than $200 including parts is pretty cheap these days. I wouldn't sweat it.
Jason
Virgil Johnson
>Considering my local Toyota dealer wanted 106.00 + parts to put a set of plugs in my V6 pickup you are getting a deal. Changing the plugs for me is 45 min. start to finish.
Re: Consider...
Grant Smith
>Consider that the labor rate isn't just labor. Here are some costs that the repair shop incurs....AKA Overhead:
-A large building with taxes at the commercial rate
-Gas to heat a large building, electric, insurance
-Employees, benefits, vacation time, uniforms, rags, fender covers
-Shop equipment (Hoists, jacks, Air compressor, diagnostic tools(and regular upgrades), diagnostic software (around $500/month)
-Hazmat disposal and compliance requirements
-Then there's the mechanics tools, usually provided by the mechanic at their own cost.
-A small possibility that the job will leak when done, (often due to defective parts) and their need to fix it at little or no charge the second time around.
-The parts, and parts overhead (Oil, Oil filter, gasket, gasket sealant, thread locker, etc.)
I have worked along side a lifetime mechanic who works in his family shop many times. This is a hard way to make a living. These people aren't getting rich unless they are dishonest.
Further, if I'm not sure what is involved in a given repair(possibly moving steering/ front end linkage, removing skid plates, possibly breaking off a bolt and having to extract it, reworking the mounting flange on the pan, cleaning it, installing the new gasket(s), maybe the rear main seal, and the obvious oil change that is included in the deal), perhaps it is best to ask the mechanic to detail what is involved before wondering if the job is being overcharged.
Sure, there are bad and unscrupulous mechanics out there, but those are the ones who need to advertise for new victims constantly. If your mechanic is busy with customers all of the time, then they are likely good enough to warrant repeat business.
This post is by no means a dig at you for asking your question. You are wise to do so, but it is OK to ask the mechanic at the time of quote what is involved, and if you are not comfortable with their response, then find a different mechanic. I always ask up front any questions until I'm fully understanding the work needed.
My mechanic buddy is often dismayed at customers who balk at quotes to fix their car. He tells me he wishes they'd come ask him what type of car, and what drive train to look for when they want a new car BEFORE they buy it, and his advice would often save them money in the long run. Instead he has to charge them $900 to change the heater blower motor in their Volvo, or $750 for a new heater core in their cab forward Chrysler because of the bad design and lowest bidder parts. Anyone got a new Ford pickup with a V-8? Did you know that the body must be lifted off (off as in completely) in order to do major engine work? Nice, huh?
I think that business is a lot like woodworking. There are many many hidden costs, and they have little choice but to pass them on to customers. Further, the work has a sort of mystery to it to most customers who don't have any idea what it takes to do a given job. Just be glad you don't need transmission work!
Sorry for the rant, I just wanted to impart a bit of the mechanics perspective to the discussion.
FWIW,
Grant in Iowa
how about 800+
Steve Jenkins, McKinney, TX.
>I had to have the oilpan gasket changed in a 2000 blazer. it was over 800 in labor. The engine needs to be nearly pulled to do it. Steve
Re: how about 800+
Stuart Hough
>From the times I have helped friends rebuild engines, and two of my own, if that was all they quoted...pay the man! That's about the cheapest repair you'll get on a car that old. Even replacing sparkplugs will run you more than that!
DB
>That is about how much it cost (a few years ago) just for the intake manifold gasket on a '76 Capri with a V6 engine. No labor included.
