ADVERTISE HERE - FREE TRIAL
OT Computer and Ebay Mystery
Jim in VA
>I am not sure when it happened, but the Ebay page no longer displays correctly on my PC. Some parts of the pages are "missing" (Most of each page is there, however.) In Firefox there are just blanks for the missing parts. In IE7, the missing parts have a message something like "Web site declined to show web page" Also, I am no longer able to work through the pages to sell an item--the pages just do not function. I am not sure what I changed/deleted/added to the PC to cause this.
A laptop connected on the same network works fine using IE7 and Opera.
The PC (the machine having a problem) uses ZoneAlarm as a firewall and the laptop runs AVG. However, I tried turning off ZA and that did not seem to fix the problem.
Any suggestions? Is there a setting I need to change? A new plug-in to add? I'd be tearing out my hair over this, but that ship sailed a long time ago.
Re: OT Computer and Ebay Mystery
Bill Howatt
>Funny it is roughly the same issue with 2 different browsers. I'd try deleting all the cookies and temporary files on the machine - for each browser if they use different areas.
Bill
Still not working...
Jim in NVa
>Good suggestion. Unfortunately, the problem remains. They mystery continues...
David Yoho
>I'd have a look at what you or someone else may have changed since your last successful viewing of the pages in question. Obviously, something on the desktop PC has changed that didn't on the laptop PC.
Did you install any new software (i.e. - anti-virus, adware/spyware, firewall programs, Web browser)? Does the desktop run an anti-adware/spyware program where the settings were changed? Were security settings for the browser on the desktop changed that might affect what you described? How about security Updates from Microsoft?
Perhaps it's something that installed itself without your knowledge (i.e. - spyware or adware) that's blocking your access to these pages. Bottom line - something has changed and you're going to have to track it down. If all else fails, you might try taking your PC back in time using the Windows Restore utility.
David
Al Stokka - Cambridge, Iowa
>Jim,
A process I've used to successfully correct error messages:
Copy the error message, exactly as it appears on the screen, and enter that message into Google's search box.
Al
Matt Berry
>There is a good chance that this is being caused by spyware. I would download and install AVG antispyware. You can find it at the following link.
http://free.grisoft.com/
Run it and see if it clears up your problem. If not you can always go through the task manager (ctrl-Alt-Delete | Task Manager) and do a google search for each item in the list. Performing an end task on anything that looks suspicious (as always end tasking the wrong thing can cause your computer to freeze or lockup / crash).
Excellent method!
Bill Howatt
Involves Java and/or Javascript
Jim in N.VA
>The problem seems to go away when I turn OFF Java and Javascript. I tried (1) updating Java and then (2) removing Java from my system and reinstalling it. Neither (1) nor (2) seemed to help. But if I go into the browser and turn off Java, things are better.
I haven't a clue as to what's going on. Any suggestions???
