OT- Frozen Gutters
OT- Frozen Gutters
OT- Frozen Gutters
John in MD
>the recent snow and ice storms are starting to melt off my roof, and teh gutter over my main entry door is filled with ice from one end to the other - probably the downspout, too.
Now that it's melting, the water is mostly dripping over the ice block and down in front of the entry, so you get wet coming in or goig out...
I tried beating on the ice with a hammer and only managed to dent up the gutter and probably poke a few new drain holes here and there..... (Looks like i'll be replacing a portion of the gutter come spring!)
I don't think I'm in danger of an ice dam forming under the shinlges - not too worried about that, but i need to figure out how to keep the ice out of the gutter so they drain.
THanks in advance for all replies.
-John-
Re: OT- Frozen Gutters
Re: OT- Frozen Gutters *LINK*
Grant Smith
>John,
You might check local stores for a heat tape. Look for a waterproof one and adhere it to the underside (or backside to keep it hidden) of the gutter using something like duct tape (maybe they have a special adhesive?) There may be an adhesive insulated wrap that can be placed over it in the same section of the store that the heat tape is sold in...
Then cover the top of the gutter something black like plastic sheet or maybe spare shingles so the sun can help melt the ice on warmer days.
Also try googling "gutter ice melt"
Here's one solution, if you have the bucks:
warmzone
Larrylverhoff@woh.rr.com
>Try this, get a pair of pantyhose and fill both legs with ice meltertie it shut and lay it in the gutter on top of the ice. If you can tie it up there if not just let it lay there. Larry in NW Ohio
What you need is self limiting heat tape *LINK*
Lee Schierer, McKean, PA
>There is a product made by a number of manufacturers called self limiting heat tape. It is a semi conductor that quits conducting once certain temperatures are reached. It is ideal for use on plastic pipe and in gutters. This is not like the old thermostat controlled tapes that could over heat. I've used some in my garage to protect pipes for over 15 years.
Lee
P.S. Mine is a different brand than the link.
Self limiting heat tape
Al Stokka - Cambridge, Iowa
>John,
Depending on the temperature, sprinkle salt or ice-melt on top of the ice in the gutter. Start at the downspout end and continue as far upstream as you wish.
Al
Thanks for the replies
John in MD
>The self-limiting tape sounds great, but could you tell me if it is either complicated or expensive? I've only got about 30 feet or so of problematic gutter to deal with, and i'm not really handy with electrical work, and this sounds like a lot of connections and additional parts needed to make the tape work....
Maybe i'm misunderstanding the info on the website...
Anyway, thanks for all who replied - i'll be replacing that length of gutter in the spring and will probably apply some sort of heat tape at that time.
Regards,
-JOhn-
Re: Thanks for the replies
Lee Schierer - McKean, PA
>I haven't purchased any in an umber of years. As I recall it was more costly than the regular thermostat controlled heat tapes, but it could be cut to any length. It also could be used on plastic pipe as it would never get above about 65 degrees. You could also cross it back over itself without a problem.
Lee
