Cleaning Proformax Sanding Belts?
Mark Kauder, Phenix City, AL
>No, Folks, I am not incredibly cheap.
I am fairly new to using my Proformax 16-32. I have quite a few rolls of various grits of sandpaper for it.
But I noticed that the major contaminate on the belt I have on there now, is glue. I have been using it to clean up some segmented bowl disks. Other than the glue, it is still in good shape. I use Titebond original. I should be able to soak the belt in warm water and clean it up.
Thoughts?
If not, I will give it a try and report.
Mark
Re: Cleaning Proformax Sanding Belts?
>Mark,
I soak my belts (24-44Pro) in Simple Green and water, scrub with a nylon brush and rinse both sides, then hang to dry with some weight clipped to the ends. Did some walnut last time that had something strange in the wood that really buggered up the belts with just a few passes. I had to use oven cleaner to get it off, but the belts are still ok.
[Yup, that's a drumsander's technical term that can be used on "G" rated sites except in England]
mm
>Mark I use a file card to clean stubborn areas on my smaller belts. I know white vinegar gets glue out of cloth but haven't tried it on belts. The file card has always done the job.
>I am interested in this. I have some heart pine I am aobut to sand and I KNOW it's going to be a bear. I ran the edge of one piece over my belt sander and completely clogged the belt and ran one piece about 18" long through my Performax and gummed up a stripe. I'm thinking of trying Paint thinner. I have already snagged a small deep container for the process.
Wonder if talc or some sort of sterates would help? I am dreading this.
>Barry I tried using chalk on the belts with some success. I didn't have an stearate or talcum to try.
>Recently I was trying to buy chalk to mark my pieces with during whatever project I was working on. Had a terrible time finding ordinary white sticks of chalk. I did find "sidewalk" chalk every where, but did not buy it because I could not imagine a use for 1" diameter pieces of chalk. Rats! Should have bought some.
Re: File Card
>Personally, I'd not use metal to clean the belts. The liquid plus a stiff bristle brush and rinse does very well and won't damage the belt or pry off abrasive. Plus, the Green tends to remove gum and extractive deposits that will tend to get reloaded and burn during reuse.
mm
>Barry,
My experience with the sander is that there are some woods, especially the sappy ones, that still need the machanical planer. I then follow by VERY light passes through the sander on the high speed to keep friction heat to a minimum. I also clean the belt in use with either a gum block or a scrap piece of plexiglass.
mm
Nelson
>Simple Green is the way to go.
Re: Cleaning Proformax Sanding Belts? - Thanks All
Doug Reynolds in Seattle
>I have used DriCoat or whatever it is called that one is supposed to use on router bits to reduce pich deposits on my drum sander belts. I just spray it on the belts and sand.
Ron in Drums PA
>I do the same as Mark does with simple green
I also have a big easer that I use to clean up the sandpaper
