Hot Melt Glue
Charles Sharp
>I hear some people use hot melt glue to temporally hold a piece of wood in place while machining it.
How do you do it? How do you get it off?
Hot Melt Glue
Charles Sharp
Re: Hot Melt Glue
Carol from AZ
>That reminds me of a funny story.
But first, to answer your question. I use an old kitchen butcher knife to break the bond. Think of it as a thin wedge with a semi-sharp edge. (That's why its not in the kitchen anymore!) Then a sharp scraper to remove any other glue residue.
The funny story.
I was teaching beginning woodworking at a SoCal community college. I showed how to use hot glue to hold something in place so the student could rout an edge more safely and more easily. So far, so good. I had specified using 4 or 5 dots of hot glue the size of a pea (for the size of the workspiece they were routing).
A little while later, a student (lady, if that's meaningful) came up to me and asked how to break the bond after she'd routed her piece. I said, "Well, just grab it and sort of twist." She tried. I tried. Didn't work. Finally got the knife out of my personal tool box, slipped it inbetween the pieces, and worked it down. Took some doing.
After they were apart, I saw the problem. There were 5 dots of glue that had squished (technical term) into the diameter of quarters, approaching 50 cent pieces! I reminded her that I had specified glue dots the size of peas and asked her to show me what she had done. She squirted out the glue. Then I did next to hers. I asked, "Do you see the difference?" She said, "Oh, you meant spring peas! I thought you meant summer peas."
Lesson learned for me! After some experiementing, we learned dots about a quarter inch diameter spaced about 4-5 inches apart that squish out to the size of a dime were the ticket. Needless to say, I never used the pea metaphor again!
Here's what I do...
>I've used a lot of hot melt glue over the years, mostly to hold pieces for machining in the pin router or the ellipse jig. I don't try to cut it, because it's too tough. Wedging or prying it with a chisel pulls splinters out of whatever surfaces it is stuck to. The best way I've found is to give it a sharp rap with a hammer *parallel to the glue line*.
To remove hot melt residue from these surfaces, I always use my "gag" chisel. I start with a corner of the chisel, bevel up and back flush to the surface of the wood, and pare the glue off in small, left-to-right increments. No muss, no fuss, gone. You'll need a scraper, though, to get the glue that remains in the surface fibers.
Ellis Walentine, Host
PS, for a gag chisel, I usually find an old flea-market firmer chisel in the 1 1/2" range. They're handy to have around for a lot of things.
Re: Here's what I do...
Kirk (KC) Constable
>I use hot melt glue for template routing. Only takes a few drops to hold the pieces together. I use a 6" drywall knife (?? the thingy you use to smooth out the mud) to break them apart. Just stiff enough to take a hammer blow.
It helps to remember where you put the glue. :-)
