Re: I don't know
Lee Gordon
>You are correct that the TV stations receive their network programming from a satellite, but I am talking about how the end user (i.e. you or me) gets the programs in his home. There are 3 basic methods of obtaining television programming in your home: over the air (referred to as OTA), cable, and satellite.
Getting your TV signal over the air is just as it has always been. TV stations transmit their signals from a tall tower and you pick them up with some sort of antenna, generally either rabbit ears or something mounted on the roof. That signal goes into the tuner that's built in to the TV set and you watch the result on the screen. Even high definition sets can work this way to receive local OTA hi-def stations. The only difference is there's an HD tuner built into the set in addition to the standard def tuner. And, of course, this gets you only the stations that broadcast over the air. To get things like ESPN, HGTV, DIY, etc., you still need either cable or satellite service.
Cable subscribers get everything (local stations and non-broadcast channels like ESPN) through the same "pipeline." The cable company receives all its programming at a central location (called the headend). Generally it gets non-broadcast programming from satellites and local stations fed to it directly from the stations via microwave links, although the cable companies sometimes pick up the local station OTA with an antenna. In either case, they send all the channels from the headend through the cable and into the box on top of your TV. Then the signal from that box goes through another cable into your TV and you can watch whatever channels your cable company provides, including all the HD programming if you have the appropriate equipment and cable subscription.
Satellite works a little differently. All the non-broadcast channels such as ESPN and Discovery (both standard definition and HD) are beamed from their headend up to the satellite and then beamed back down to the dish at your home, where they are converted into a signal that your TV can display. (Again, to receive HD you need the appropriate equipment and service agreement.) In most cases, local standard definition stations are also beamed from the satellite provider up to their satellites in space and then back down to you. They have sophisticated software to keep track what local stations their customers are entitled to receive so, for example, people in the Boston area get the local Boston stations, not ones from San Francisco. In the TV markets that are too small to justify the expense of equipment for uplinking and downlinking local channels, the customers get their ABC, CBS, NBC, Fox, etc. programming from network affiliated stations "imported" from various larger stations.
The way the satellite providers treat the digital versions of local stations (where the HD comes from) is a little different. In addition to the normal decoding equipment built into their set-top boxes, there is also an over-the-air hi-def tuner whose sole purpose is to receive the local digital stations. The set-top box combines the output of that tuner with all the programming being beamed from space and sends it all, seamlessly, to the TV. So, in order to receive, say, NUMB3RS in HD from your local CBS station (a program that the local station picked up from a the network via a separate satellite and sent, along with all the local commercials, etc. to its transmitter to be broadcast over the air), a satellite customer would have to get it directly off the air via the satellite box's built-in HD tuner.
I trust you are now more confused than before.
