steam damage to table
karen
>I really blew it today. Sans ironing board, i ironed 2 shirts on our dining table. I used a thick, double folded towel, but found that when i removed it the table looked like it had had a case of frost! The 'frost'has stayed on and as the table is not mine, i am doubly concerned. The table is in general need of (planned) refinishing, with a fairly battered dark stain. My questions: Have I permanently ruined the table? can the white patch (1' x 2') be removed/fixed in the stripping and refinishing process? is there anything that can be done before that time as a quick fix? Any info/advice much appreciated!
KW
Re: steam damage to table
Re: Don't panic - no major harm done!
Larry Clinton At Frankfort (Central)., Indiana
>This is no worse than setting a water glass on the table and finding a white ring when you remove it. I am not a pro, but have removed these white rings / spots myself. The white / frosty appearance is nothing but water in the finish. Sometimes this can be removed by taking a DRY towel, laying it on the white area and ironing the towel with a DRY iron (no steam at all - empty the iron before doing this)on medium heat. Don't get the finish hot enough to make it sticky or you will be learning how to "rub out" the finish with a rag and compound. Depending on what type of finish is on the table (shellac, lacquer, poly, varnish etc., some times a wash with alcohol will work. You will probably get a lot better advice from others on this site who are professional finishers. As to your other question this will have no effect on re-finishing the table as the coating containing the moisture will be removed during the stripping procedure.
I almost agree
Lee Schierer, McKean, PA
>I agree with the dry iron and dry towel approach. It works quite well. Stay away from the alcohol unless you are ceratin it won't soften the finish.
Lee
explanation of what happened
bill tindal, E.TN
>what has happened is the water has dissolved into the finish and crazed it. Crazing is a complicated polymer phenomena where bazillions of tiny cracks form in the polymer film. These cracks scatter light and appear white, just like snow is white but ice is clear, yet they are both frozen water.
Neat crazing demonstration. Bend a CD disk almost to the point of cracking. Dribble rubbing alcohol on it. Bam, it shatters.
The fix is to heal the cracks and that can be done as described in the other posts.....Or..... There are also aerosol cans of slow evaporating lacquer solvent that can be sprayed on and the finish dissolves and redeposits as a clear film.
karen
>Just wanted to thank you guys for your v. helpful responses. After ironing away (something i never would have thought of without your advice/info) it is 80% improved, acceptable enough for now. And knowing more about what was really going on made sense of the water drops that appeared! Thank YOU!
