200+ woodworking book reviews
viberation in jet 1442 lathe
ben d.
>To someone that has or turns on a jet 1442vs lathe, how much viberation do you have when turning a small hollow form 4 1/2T and 4 in' dia. Wood is fairly soft riverbirch wet but not green and the same on an 8 in' green cherry by 3 in. deep. Lathe runs smooth tools sharp tried different speeds head stock tight material being held in Nova chuck all tight. Viberation not noticable on spindles or when shaping a bowl round with the tail stock up but when you start to turn from the end it really chatters. I know some is normal but seems to be getting worse.
Jet rep, after much conversation suggested to take to repair station, he had no suggestion.
Re: viberation in jet 1442 lathe
Stuart Johnson
>Ben,
I don't have the lathe so can't answer your question but you might have better luck if you repost over on the turning board.
Glenn Madsen near San Francisco
>My experience with the lathe you mention is similar, but I doubt that it's the lathe.
Green wood is wet (duh!), and the distribution of the water in the blank is not necessarily even across the grain. Different parts of the tree do different things, and the cells hold/release their fluids at different rates.
Minor imbalance is a part of the price I pay for turning generally free, easy to cut woods. It's and easy price to pay.
And check out the turning forum for WAY more info. Look to your left, if you have the frames view up.
