Router with a dynamic brake ?
Pete LaBelle
>Does anyone make a router with a dynamic brake that stops the spindle fairly quickly?
Working on a fixture here at work that could be done much easier if such a tool existed.
Thanx.....
Pete
Re: Router with a dynamic brake ?
Larry Clinton At Frankfort (Central)., Indiana
>If you are using a router with a single speed (no speed control) you could rig up a relay to turn the router on / off. If you do this you can use the "off" contacts of the relay to short out the line in and neutral of the cord feeding the router - with a resistor in series. The universal motors (brush type) used on routers and many other small tools actually turn into a generator when spinning with the feed power off. The resistor should be a wirewound - guessing in the 50 watt range and about 5 - 20 ohm. This is just a guess for a 1 1/2 hp router. May take some playing to determine what is needed. If the resistor isn't big enough wattage wise, it will get very hot, very fast. (Ceramic coated wirewounds can run at almost red heat without damage though.) A lower resistance in Ohms will stop the router faster (and get hotter), this is harder on the brushes and armature of the router. I would start with a 50 ohm and work down till your satisfied.
Keith Newton
>My newest Makita 3612 has it. I have three of this model, but only the most recent one has it.
PC7529
Hoa Dinh
>PC7529 has electronic brake. But the control unit (also controls speed) has some problems so PC decided to drop the electronic brake feature in the PC8529.
My PC7529 still works like a charm.
-- Hoa
