Filling small gaps
Filling small gaps
Filling small gaps
Ken Krawford
>I am completing some built in bookcases. They have face frames with the carcass of plywood. At the edges where face frame joins the plywood, there are very tiny voids (less than .5 mm). Much too small for wood filler.
Any suggestions on what to fill with, bearing in mind that these are vertical surfaces.
Re: Filling small gaps
>What finish are you planning on using? What wood also?
>Hi Ken,
I'm not sure why you feel these gaps are too small for wood filler. With a putty knife you can fill just about any surface imperfection.
mike mcnerney
>depending how how many lineal feet I had and how noticeable. I have used thick crazy glue, put a bead on & push it in with you finder with or without a disposable glove, then spray on the accelarator.
scrape &/or sand to clean up.
5 min epxy is thicker therfor better but messier & mor clean up & sometimes you have to wait a half hour before cleanup.
water base pore filler or even water base urethane is my 3rd choice a 2hre wait to clean up.
Or try thinning whatever kind of plastic wood you use with the appropriate thiner so you can push it in with a putty knife.
4 of a hundred ways
mike mcnerney in ottawa
Ken Krawford
>I'm using Famowood filler. The cabinet is birch plywood with poplar face frames. When I sand the filler, all the filler is gone but the crack remains. I'm going to paint the piece when finished.
pecker
>When I have really tiny gaps to fill, I will use DAP Plastic Wood and force it into the gap with my thumb, rather than using a putty knife, which just smears a layer over the gap. This might be painful if you had to do 8 feet of it, though.
Since you're painting, maybe try something less thick...more like a caulk consistency.
