I didn't miss the point, your turn......
bill tindal, E.TN
>I didn't miss the point from your article, but I didn't explain it either in the above post, using instead "set" as an approximation of this critical parameter. I was trying to avoid a detailed technical summary of your article. But, I'll give it a try and you can improve on my effort. Most of these readers will not be able to see your article in Wood Shop News.
What is important is that during sawing the back of the blade not be constrained by the width of the kerf. As the blade cuts it wobbles/fluttters/flexes slightly in response to localized variance in the wood being engaged by the tooth tips. If during one of these flutters the back of the blade becomes constrained by the width of the kerf the blade will deflect and track away from a straight path. If the blade is not constrained by the width of the kerf these fluttters/ flexes are self correcting and the blade cuts straight, yielding flat boards/veneer. While not stated explicitly in the article it seems this same argument will apply to the guides. They should not constrain this micro flutter during cutting.
What determines whether the blade can micro flex/flutter freely, without kerf constraint, during cutting is the angle formed by the tip of the tooth and the back of the blade, as described in the formula. This angle is dependent on set, blade width and thickness. If one wishes to get the approximate concept across in a sentence one might say the blade needs sufficient set, because set is the only variable once the blade width and thickness is specified. However, it follows that a wider-thicker blade will need more set than a narrow one.
A table of minimum set vs blade width/thickness to achieve the critical set angle would be very handy to have at hand. We all can easily measure set.
