Help finding an assembly bench base...
Rob Hix - King George, VA
>Hey all,
After a recent knee injury I am finding it hard to bend down and work on my low-level assembly table that I use when building smaller pieces of case goods. Somewhere I remember someone posting a picture of and assembly table they made with a scissor lift base. I have been searching the net far and wide for a scissor lift base, but cannot seem to locate one.
Could someone help me find one of these bases?
Thanks in advance,
Rob Hix
Re: Help finding an assembly bench base...
Ed Mulligan, Cape Cod
>Rob -
Look for hydraulic lift tables. Here's one:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=41145
Adjustabench a possibility?
Bill Hylton
>I don't know off-hand about scissors lifts, but I recently got Adjust-A-Bench legs and casters from Geof Noden. Mounted them under my existing benchtop. The range, with a 1 3/4" thick top is about 28 1/2" up to 45". The height adjustment is man-powered, one end at a time.
Website is www.adjustabench.com
Take a look if it sounds like a possibility for you.
Bill
Re: Assembly bench article in Woodwork mag
Earl Davis
>Rob,
There was an article in the June 2004 "Woodwork" magazine (#87) by Roger Heitzman, about his quest for a perfect assembly table. He gives some sources and describes his design process.
Good luck,
Earl
Howard
>Rob:
I built this bench and it was the smartest thing I ever did. It is a joy to use, saves my back and knees.
I did modify the base design slightly. E-mail me if you have any questions.
Howard
Hospital beds
>A friend of mind picked up a discarded hospital bed chassis, which is exactly what you're looking for. He made a top for it, plugged it in, and, Ouila! You need to network to somebody in your local hospital system to find out what they do with old beds.
Ellis Walentine, Host
