Way OT: Rod Peterson, have you seen these? *LINK*
Re: Way OT: Rod Peterson, have you seen these? *LINK*
Yep, I've seen 'em all.
Rod Peterson -- Ormond Beach
>Some of them are pretty lame and probably never really happened, but I'm sure in one form or other some of them did. Two of my favorites are the Speedbird in Frankfurt and the female ground controller.
The squawk sheet is more believable and some of them are really hilarious.
I have a friend, Vinnie, with whom I worked for years who is alleged to have done the following during the afternoon international inbound rush to ORD:
Speedbird 512 Chicago Center, Speedbird 512 descending to Flight Level 240.
Vinnie (in normal English)Speedbird 512, descend to 10,000, altimeter 2997.
KLM 345Chicago Center, KLM 345 descending to Flight Level 240.
Vinnie (in normal English)KLM 345, descend to 10,000, altimeter 2997.
Alitalia 27Chicago Center, Alitalia two-a seven descending to-a Flight Level two four-a-zero.
Vinnie (in Italian accent)Alitalia two-a seven, descenda to 10-a tousand, altimeter 29-a-9-a-seven.
Alitalia 27Chicago, you make-a fun of da way we talk?
Vinnie (in Italian accent)No, I make-a fun of da utter guys.
Even if he didn't really do that, I'd like to think he did.
Rod
Clock INOP
ben
>Believe it or not I have see the Clock in op / wound clock write up and that is a perfectly acceptable corrective action. The $100M dollar F-15E actually has a wind up clock in the rear cockpit.
Re: Clock INOP
Bart Leetch
>I had one in an EA6B Prowler.
ECMO gripe on the yellow sheet A/C doesn't work in the off position.
I did check it out when the mechs turn the aircraft.
Signed The gripe off "turn it on stupid". The same ECMO was on the next hop & his face turned real red when he read it. Funny we never did have a problen with the A/C on that air craft.
