Veritas - Innovation in Tools
Minimax & Electrical Engineers
vlad
>Hi folks,
I purchased a Minimax SC3 with a 5HP 600V 3PH motor. Can I put a capacitor on the motor to run it at 220v 1PH? What will be my HP drop? Am I better off replacing the motor? I have a source for cheap motors & rework so not too much concern there. I understand Leeson can do custom machining to fit the European pulley on their motor.
Finally, any source for Minimax parts new or used? I need some knobs and such.
Many thanks in advance.
Vlad
Re: Minimax & Electrical Engineers
Miles
>Not an EE but you can't convert 3Ph to 1PH just like that - or we'd all be doing it! You'll have to use a phase converter, or change the motor (better idea - you get to choose a good one if you want to!).
Just think of all that lovely industrial machinery with 3Ph motors, that we can't just ship home and fire up.... shame!
Miles
Howard Norman-Prescott, AZ
>No, you can't just add a capacitor and get the motor to run on 220 single phase. The best think to do is to change the motor out. It would require a phase converter plus a transformer to match the voltages to use the present motor.
Howard
Re: Minimax &EE, etc., phase converters
Carol from AZ
>I have a question here. If a person put a phase converter in place to operate a 3ph motor, would one need a second phase converter to operate a second 3ph motor?
Or, can one think of a phase converter as sort of like an air compressor, supplying the needs of multiple 3ph motors?
Inquiring minds, etc.......
Jim Swank
>Yes Carol, that is possible, though it can get a little complicated if you want to run more than one motor on the phase converter at the same time.
Re: Minimax &EE, etc., phase converters *LINK*
Tom Stockton
>Yes as long as the phase converter is sized for the largest load and you don't try to start two motors at once. I believe you can run up to 3x the hp rating of the phase converter as long as wire are sized correctly.The link below has good info.
Tom
http://www.owwm.com/FAQ/3Phase.asp
Wayne in Topanga
>Carol,
If you use a rotary phase converter you can power any 3phase motor as long as stay within the power rating of the phase converter and the voltage output matched your motor.
Static phase converters are a bit less universal. They are usually made to match the requirements of your motor. However, if you have more than one motor of the same horsepower you should be able to power either motor with the same converter.
Work Safely,
Wayne
Jim Holman
>Yes, it is possible. Not recommended for applications requiring high torque. I have done it for years on an old Oliver lathe and it works. Don't know the HP loss but there is some. Lindsey publications has an excellent book on this subject.
If you are buying from auctions *LINK*
Keith Newton
>You are probably not paying more than 10� on the $, so you should just go ahead and buy a new single phase motor from the manufacturer with the savings.
If you have never looked at the online auctions, here is a link of one that closed today. Check out the stroke sander item #16 Ha
http://www.irsauctions.com/index_lots.asp?pg=details&id=9734
Really???
Brian in Brighton
>I thought that 3 phase motors could not be run on single phase because of the wiring inside the motor? Are you using only 1 of the 3 sets of windings?
Brian in Brighton
Phil in NJ
>Are you sure it's really 600V 3phase? Is it possible you're seeing insulation rating on the motor referred to as 600V?
If it is a motor made for the US, for 3 phase it would be much more likely 208V 3ph or maybe 460V 3ph.
GolfSteve in Calgary
>600V three phase is a standard up here, although in my region 480V seems to be more common.
I get the impression that 600V is more common in Eastern Canada and 480V is more common in Western Canada. According to my co-worker 480V used to be the standard but, in the mid-80's, the standard was changed to 600V.
Steve Jenkins, McKinney, TX.
>Carol, when I moved from Dallas to "the bushes" I no longer have 3 phase available. I bought a large rotary convertor and use it to supply a 3 phase breaker panel. All my 3 phase equipment is run from this panel. I just need to be sure to turn on the convertor before turning on anything 3 phase. I sized the convertor so I can run anything in any combination I want. Steve
Carol from AZ
>Thanks, Steve.
I don't have a particular project at hand where I need to know this stuff. But it may happen. Now I know I have options. Always a good thing.
here goes
Jim Holman
>I am not an EE. I am a tinkerer and I read a lot. 220 VAC power in the USA is actually 220 VAC 2 phase. The two hot legs are 110 VAC each, measured to ground, and 180� out of phase with respect to one another. Three phase power consists of three hot legs out of phase by 120� with respect to each other. Two of the legs will be at 120 VAC with respect to ground and the other will be at a higher voltage, in the 190 VAC range.
My old Oliver has a true three phase motor, 1950's vintage. It is powered by 220 VAC as follows. Each of the hot power legs is wired directly to one of the motor leads/windings the third motor lead/winding is connected in series through a large, 5.6 mf, electrolytic capacitor back to one of the hot power legs. Supposedly this capacitor shifts the phase of the voltage enough so that the motor will start and run. The theory escapes me but my lathe has worked for darned near 25 years wired in this manner.
I do not endorse or recommend this method. Read Dave Gingerly's book on 3 phase power as I recommended previously
