ADVERTISE HERE - FREE TRIAL
Can I Mix ...
Can I Mix ...
Can I Mix ...
Jesse in New Mexico
>Can I mix two batches of wood with different moisture content? How close does it have to be?
The story is... a work in progress got redesigned and made more ambitious in midstream. I had to buy more lumber. The first batch of lumber is at 6 or 7% and the new batch is at 8 to 10%. I've had the new batch in the shop for a couple of weeks, and its not budging.
The lumber is 5/4 and 4/4 walnut. I'll be using it for a table top and a buffet with panels, so flatness is important.
Can I go ahead with this,or am I asking for trouble once the new stuff finally dries?
Thanks in advance!
Re: Can I Mix ...
Re: Can I Mix ...
Keith Newton
>I think you should be OK in that range if you use good methods.
