Contractor Saw Stand Designs *LINK*
Mark Kauder, Phenix City, AL
>Do any of you want to share your designs/pictures of your shop made Contractor Saw Stands?
If you go to the shop shots on my website, you MIGHT be able so see what I have my old Craftsman TS on. It is a mobile base that I built from ShopShots Magazine, probably 7 years ago. It has a dust bin in the middle, and some storage on either side of the dust bin.
My TS has cast iron wings on the right, with a JoinTech SawTrain precision fence, and the left wing contains my Router, with a router raiser unit, which is used infrequently.
I am interested in building another mobile saw base, but one that would have much better dust collection/containment for both that saw and the router. If it had a little bit of an outfeed table, that would be great. I like the idea of storage under the wings for router and TS bits and pieces. It is alright if the tilt adjustment is hard to get to, because I never tilt the blade - only using the adjustment to ocassionally, make sure the blade is 90 deg to the table. I do, of course need access to raise and lower the blade.
I am looking for ideas.
Please not suggestions that I spend a bunch of money on a cabinet saw.
Thanks All.
Mark
http://www.markkauder.com
Re: Contractor Saw Stand Designs *LINK*
Great Idea Mark
Howard In Toronto
Robert Hutchins
>Howdy Mark,
Sandor Nagyslanczy's(sp?) book on shops - sorry, don't have the exact title at hand - has lots of good pictures for ideas. I remember Carol Reed's California shop pictured with a contractor's saw stand/surround that she custom built. Maybe Carol will join the thread and give you the details. If you're interested, PM me and I'll see if I can find the book and scan some of the shots that appeal to me. Might take a few days (weeks?) though.
Bartee (metro Atlanta)
>Mark,
Here is what I did. One of the big reasons I did this project was to gain experience in the shop. I learned a lot.
That said I really enjoy the function of this base. All of my tools for the saw are in the top left small drawer, so changing blades is very easy. As you can see from the pictures the right drawer has all my standard blades. The big drawers were designed for 10" blades.
The construction is HD Sandeply, poplar and Birch Ply drawer fronts.
The left large drawer now contains my Freud 508 dado which makes it far easier to use since I can easily pick each blade for a set up.
I like the adjustable feet so I have a rock solid base for my saw.
The pictures show a lot of the mistakes I made and some of the over engineering.
click on picture to go to album
Carol from AZ
>Hi, Mark,
My SoCal shop saw was an old Craftsman bench top built into a cabinet to which I had attached a Biesmeyer fence. Used it for years. It is indeed in Sandor's book. One advantage to the bench top saw was the motor was inside the base. Contractor's saw present a different problem.
I began by determining how high I wanted the saw table off the floor. Then I chose the wheels, all swiveling, all locking, 3" minimum diameter. Subtract the total wheel height and the saw height (in your case without the legs) from the overall height, and you have the saw base cabinet height. My cabinet base had a 'dust panel' frame for a top. Beneath the frame top was a bottomless drawer. Hanging from the bottomless drawer was a plastic garbage bag. The dust frame panel is the hardest to explain. Think of it as a frame w/o the panel. The stiles were 3" wide by 5 feet long. The rails were 18" long and wide. That left the 'hole' in the middle for the saw to span, allowing the sawdust to fall into the bag below. That was my dust collection. Hey, my shop in SoCal was cleaned first with a shovel, then a broom and finally a leaf blower!
BTW, the width of my saw base cabinet was 5 feet, the reason being the cabinet was made of BB plywood, 5 feet being its native width/length, and 5 feet fit in the shop. The wheels were attached to that 5 foot piece. The depth was 2 feet, as I recall.
The outfeed was piano hinged on the backside, with card table hinges on the legs and shop made adjustable feet to compensate for the concrete floor. I attached the Beismeyer to the front, planted the saw behind the fence, squared the saw to the fence and bolted it down. Then I built in small cabinets (again out of BB 1/2" plywood, with 3/4 Melamine tops) that fit between the saw base cabinet and the saw table top for either side. The tops of those side cabinets also provided saw table extension support and support for the outfeed table to hinge off of.
Barb Siddiqui built something like it off my idea. Finally, there is at least one picture of it in the Shop Tours on the left menu here. Give a holler if I wasn't totally clear. I am preparing for a Hebrew language test tomorrow or I would whip up a drawing for you.
Barb Siddiqui
Barb Siddiqui
>Mark- Mine's been in shop shots here since 2001...yikes. I built it for a Sears contractor saw
(the better one made by Emerson) and have loved it ever since. After these pix were taken, I put an acrylic downdraft table in the left wing, which works terrifically (second link.)
Though now, sadly, I mostly roll the whole thing out of the way for use of the mini-lathe!
http://woodcentral.com/shots/shot261.shtml
http://woodcentral.com/shots/shot343.shtml
Barb Siddiqui
Barb Siddiqui
>Sandor's book is great for many shop ideas, and is out in a new revised edition which I intend to review as soon as it's delivered to my door. Now in paperback.
Carol's saw stand is in this, as well as others:
'Setting Up Shop'
Ted Wong
>I designed one for Woodsmith back in 1996 or 1997. I can't remember the issue #. It had a clever wheel raising and lowering mechanism that was pretty solid when the wheels were in the up position and was pretty easty to lower the wheels for mobility.
I e-mailed an AutoCad file to you.
Brian in Brighton
>Let us know how it works out.
Brian in Brighton
