A55 Smoothing Plane
wood movement?
wood movement?
wood movement?
Al Hillier
>My daughter wants me to make a large cutting board/table. I am thinking of using 4/4 maple, gluing 3-6" boards together, planing the 12" wide pieces to about 7/8", gluing three 12" wide pieces together to make 36" wide pieces by 4-8'. I would then crosscut 3" pieces and glue them together to make a surface 3" thick and about 3' x 5' with the end grain up. I'm planning on gluing a 6" apron around the surface and mounting the top on a pedestal base.
Will I have a problem with that much solid wood moving and/or warping? If not, could I intersperse some walnut and cherry strips to creat a pleasing pattern? Would that be more likely to warp? Comments would be appreciated.
Al
Re: wood movement?
If I understand you correctly...
>...this is a big endgrain maple butcherblock about three feet by five feet and 3" thick with a frame around it. Warping isn't really the right word for the possible failure mode here. If your maple is dry and all these pieces are glued up well, I don't think it will want to warp and/or twist, but it will definitely move in both width and length with changes in humidity. That will pose a problem for your "apron," unless you figure out a way to let the butcher block float within it. Over a large surface like this, the seasonal movement will be fairly significant, so a floating panel type arrangement will involve some large gaps in winter. You'd be better off without the apron. Instead, how about a beam arrangement under the butcher block to keep it straight and flat? Two long beams connected by two or three cross beams would provide you with a rigid platform for your table top.
You realize that the top of this table alone is going to weigh at least 175 lbs, don't you? With the beam platform, you're looking at 200# or more. Better plan on a sturdy base, too.
Ellis Walentine, Host
Re: wood movement?
Re: If I understand you correctly...
Keith Newton
>I have a good friend in the re-finishing business that wants me to repair a piece that is less than 2' x 2' that has blown one of the rails off, and the others are loose.
I could put it back on, but it would not do any good, it will self destruct again.
Re: wood movement?
Re: wood movement?
Howard Acheson
>What you plan to do is the way end grain butcher blocks are made. Here is some info that may help.
There is a little engineering that needs to be considered when building an end grain butcher block. First, choose wood where the growth rings (viewed from the end) run as close to 90 degrees or parallel to one edge. Remember, the expansion/contraction is about double along the annular rings verses perpendicular to the rings. You've got to keep the grain running in the same direction as you glue up your strips. In other words, don't glue a flatsawn edge to a quartersawn edge.
Next, the way butcher blocks are made is to glue up strips of wood like you were making a laminated type cutting board. These laminated panels are then run through a planer to flatten them and bring them to equal thickness. Then the panel is crosscut into strips of blocks equal to the thickness that you want the butcher block to be. These block strips are then glued together again keeping the grain running in the same directions.
Not paying attention to the grain orientation will lead to the block cracking and/or joints being pulled apart.
A type II adhesive will work just fine however, you need to be sure you do everything right to get good adhesion. Your glue faces should be flat and freshly cut. It they were cut more than a few days earlier, freshen them up with about three swipes with 320 sandpaper and block to keep the faces flat.
Generally, threaded rod is not used as maple has quite a bit of movement when it's moisture content changes. Threaded rod would restrict this movement and either deform the block or pull the nut/washers into the wood when it expanded leaving the rod performing no function when the wood later shrinks. Proper gluing will keep the block together.
It always much cheaper, and a lot less aggrevating to purchase a butcher block than to make one. The firms that specialize in end grain butcher blocks have speciaiized equipment to apply the necessary clamping force, plane the initial boards exactly correctly, plane the first glue up and then clamps to make the final block
Finally, you can not surround the butcher block with a border. The butcher block will expand and contract with changes in seasonal relative humidity and the border would want to restrict that. Something will have to give.
