Re: Veneering Face Frame? *LINK*
Jack Lane
>Craig,
I run a cabinet shop and one of the services we offer is cabinet refacing. The product we use to cover the frames is called Wood-over-Wood. It's two ply with the select species over a layer of luan(like real thin plywood). We use StarStuk spray contact cement to attach it to the frames. That's a pricey set-up so I'd recommend using regular aerosol spray contact cement (like 3M) to stick it. Just use a piece of laminate or a board to keep it from getting all over everything as you spray. Also, don't try to roll this stuff out with a J-roller. You can't get enough pressure on it. Use a piece of plywood or masonite like a scraper only cover it with a piece of cloth. Put a lot of pressure on it to make sure you get a good bond. You can also use ice scrapers if you have them available.
We finish the full sheets of WOW in the shop and use a hand held Virutex laminate slitter to cut it. A straigh edge and sharp razor knife works well too. We cover the inside and outside edges of the rails/stiles first and cover the front of the frames last. You would use nearly the same procedure you would use if you were covering an item with high pressure laminate. I always assmemble the pieces of WOW on the front of the frame the same way the orginal rails and stiles were assembled. At vertical joints I cut the piece a little long, glue it, and cut using a combination square as a guide.
Trim everyting you can with a NEW flush trim bit.
This system works better than any other method I've seen. The peel and stick stuff is easy to screw up and get bubbles under and the phenolic backed leaves black lines in places you don't want them. We buy our WOW from Keystone Wood Specialties. Good luck
Jack
Keystone
