Anyone ever heard of a 3-1/2" long router bit???
Steve Yakoban
>I've got a bit of a construction problem. We're going to change the 40 yr. old sliding patio doors to new ones which we bought. The rough opening is to size of the new door assembly. I need to create at least .250" clearance side and top to let the new assembly have expansion clearance. I can't remove any studs for planing because the vinyl siding is trimmed to it.
I know I can run a circular saw around the inside side of the 2x4 frame and chisel out the corners, but if a long router bit exists, it would be much easier and faster. Anyone ever heard of a 3-1/2" long router bit?
Re: Anyone ever heard of a 3-1/2" long router bit???
Kirk D.
>Try Magnate in California. Google Magnate for the website. I think they have some really long spiral straight bits.
Also try Woodworkers Supply
Ray Thompson - Middletown,IN
Rob Sandow
>I once saw an episode if NYW where Norm used a long router bit like that to cut ogee patterns on the ends of 6x6s for a pergola. It was not fast at all. I would suggest the circular saw method might be much faster, even if you have to do some manual chisle work at the end.
Rob
Keith Newton
>I am not so sure that you would get the results that you are thinking from the router.
You might try screwing on a straight edge to guide a shorter bit just to trim the siding. But for the cripple stud, I would suggest that you try a circular saw, by holding or wedging the blade guard back, and lightly slide the blade side-ways down the board. If you keep the nose of the base in contact with the edge of the work, it is not as hard to control as you might expect.
You can finish out into the corners with a right-angle grinder.
1/2" Dia. 2 Flute Endmill @ Enco
Charles Sharp
>Be VERY CAREFULL when using endmills in wood, they are very agressive. I would use a bushing and guide board, also take the cut in steps.
If I were doing the job, I'd use a couple of saws.
JW Ohio
>Would it be easier to build up a "2x4" by laminating pieces of wood with spacers in between to create the pocket or cavity you need instead of chiselling or routing it all out?
Wood glues these days don't fail before the wood does. You may want to consider this oprion?
JW
Re: SawzAll
Al Stokka - Cambridge, Iowa
Some other Ideas....
>I did this recently.
In my case, I used a Sawzall with a metal cutting blade and inserted it between the edges fo the studs and the sheetrock and strom siding, cutting any nails in the edges of the jack or stud. then I pulled it out having removed any nails in it ans replaced it with a jack I had run through the planer to an 1 1/8". I was about to do the same thing across the top.
Another approach might be to clamp or screw boards up each side of the wall/opening temporarily that are paralel to each other. Then use them as "router rails". Put an ordinary short bit in the router and rout the "face" off the jack. Be sure to remove or deeply set any nails you might hit with the router. This will get you within about three or four inches fo the corners. Chisel that part off. As my Dad used to say, you ain't building a piano.
Shhh....don't tell anyone!
Lee Schierer, McKean, PA
>I've found that you can use metal cutting end mills on your router if you run them at slower speeds. They also cost considerably less than router bits. Your local metal cutting tool dealer or tool shop should be able to help you locate a longer end mill. But don't tell anyone!
Lee
Re: Shhh....don't tell anyone!
Ray Newman
>Now you let the cat out of the bag....
I had a 3" X 1/2" bit that I used
Don Henthorn
>to make through mortises in door stiles for the through tenons on the rails. I think I got it from Woodworker's Supply but that was a long time ago. There wouldn't be much to chisel out after using that.
DB
>Use a mortiseing bit in your router. Attache straight edges to the inside and outside of the wall. Adjust the depth of the bit to cut into the stud 1/4" or what ever is needed. Might have to make a larger base for your router. Also watch out for nails.
I have a Jesada #880-515, 1/2" solid.............
Art Silva
>Carbide upcut spiral bit that is 4" long with a 2-1/2" cutting length. Freud's #75-308 has a 2" cutting length with 4" length. I use the Jesada for cutting mortises. Either bit costs mucho dinero! Be aware that using bits of this size "freehand", without an edge guide, etc. can be a handful. The torque reaction will be considerable.
