200+ woodworking book reviews
Belt Grinding Jig
Belt Grinding Jig
Belt Grinding Jig
Tom MacGregor
>When I discovered that I didn't need a machine shop to work aluminum my jigs & fixtures took a leap forward. I wanted to do rough work and new bevels on a belt because it's wide, flat and runs cooler than a wheel. Light finger pressure on the rubber tip thumb screws takes this jig on & off and it's far more accurate than I expected. I can change between any of a half-dozen grits in about 60 seconds. A 240 grit belt leaves a wire edge that needs only a quick hone and I had no problem at all with overheating the edge. This is a 50 cent flea market socket chisel ground with a skew. It has my first-ever turned replacement handle made of lacewood. I'm very happy with the results.
Re: Belt Grinding Jig
Re: How do you change bevel angles?
Tom MacGregor
>The bevel angle can be changed by tightening the clamp closer or farther away from the cutting edge. It just looks like there's not much room for adjustment in the photo because that old chisel blade is getting short. I'm making another wider clamp for plane blades that will take anything up to a #8 size iron.
Aluminum
Garrett in Victoria BC
>Al can be worked readily with most ww tools, and since it has no internal stresses nor grain, often much more easily.
I needed to make a mast saddle to raise the boom hinge on my boat. (Welding tabs directly to the mast would have required taking it down and delivering it to the shop, not a trivial job with the radar, and several antennae to be disconnected and removed.) I also needed to make a mounting plate for a new dinghy winch.
All material is 1/4" thick. The saddle is a 6" length of 4" o.d. schedule 40 pipe with a 3 1/2" i.d. which matches the o.d. of the mast perfectly. I set it in a vee block made from a short piece of 2x4 and cut it in half lengthwise freehand using a regular 6 tpi band on the bandsaw. (A hacksaw band quickly becomes useless as it loads up.) I also used both the bandsaw and a jigsaw to cut out the tabs and the flat plate. A medium rasp produces a decent finish on cut edges.
The only difference with wood comes in the finishing. To ensure a long-lasting finish, it's imperative to use Zinc Chromate as an undercoat. The only surface prep is to have it clean and dry. Once a couple of coats of primer are on, any paint suitable for metal will produce a good finish.
Cheers, Garrett
Fred
>Great idea Thanks
Re: Aluminum
jeff
>Garret
A few questions:
How do you weld the aluminum?
What do you do about the chips that mix with the wood dust?
Jeff
Ernie Miller
>more details? how is it held on? do the wing nuts just clamp it on? if so how does the rod turn? I like the idea so many chisels that need rehabing so little time.
Tom MacGregor
>The rod doesn't turn - the clamp isn't attached and you hold it in place by hand and put the amount of pressure you want on the blade. You can't see my hand in the picture, but I was holding the chisel handle to keep everything in place. You can slide it back & forth on the rod to use the whole belt, too. The thumbscrews on each side have soft rubber points (maybe plastic) and grip so well that you can just snug them up with light finger pressure and the jig holds so well you can pick the whole grinder right off the bench. McMaster Carr has the screws. The rod is held in the holes in the side plates with a drop of Loctite #609 retaining compound. I used metal to metal threaded inserts for the thumbscrews thinking that threads in the aluminum wouldn't hold up, but it takes so little pressure to hold it in place that it wasn't necessary. Most of the aluminum came out of the local recycling bin.
