Don't do it.
Angus Barclay, in New Zealand
>MDF on its own is not the right material for this job.
Spackle and paint can give a good looking edge but it still won't be durable enough to use in a bathroom. The drawers or doors will inevitably get a chip somewhere (most likely an edge) and then you will discover how badly MDF reacts to moisture.
Yes a small chamfer will help, but that's kinda contrary to the clean look your wife wants.
MDF edges are easily damaged and you really do need to put on some sort of edging strip.
Put a "sizing coat" of thinned yellow glue on the edge of the MDF, let it dry, then glue wood strips on the edge.
If you're planning to paint the doors, you don't need to fuss with miteres on the corners. Either handplane the edge strips to size before gluing or trim flush with a router after gluing. Because you're going to paint, you can even cheat and use a bit of filler for any minor imperfections.
The usual precautions and advice about MDF apply:
* - use the best possible dust protection.
* - it soaks up finish, so use a good oil-based primer/undercoat.
* - the edges soak up glue, so use thinned glue as a size.
* - edges damage easily, so handle with care in the shop.
regards
Angus Barclay.
