The right glue for furniture repair?
Steve Yakoban
>We just had a good sized wardrobe cabinet stripped for reclamation as a usable piece of furniture. The piece is probably about 65 years old, some pine type of paint grade wood with very few knots, intended to be repainted again.
There are a couple of cracked boards - one is from use of a corrugated fastener that caused a split about 10 inches long.
What is the best type of glue for fixing these splits/cracks? I have a good grade of yellow carpenter's glue, but is there something better? Will any chemical stripping residue have any affect on gluing?
Also, is there a recommended wood filler for this (to be painted) piece? Any other pre-painting tips?
Thanks guys!
Re: The right glue for furniture repair?
Ed Mulligan, Cape Cod
>Yellow glue is fine for furniture repair. Some folks use hide glue for joinery because it easy to 'unglue' should the need arise.
It is important that the surfaces to be glued are clean, fresh wood. Use sandpaper in the crack to clean out the stripper and get down to clean wood. If you can't get the crack clean you might be able to kerf it with a saw and install a new piece of wood in the kerf. Another workaround is to reinforce the crack from the underside with canvas or wood glued on.
For painted surfaces the best material for filling cracks and dings is autobody filler such as Bondo.
Ed
Steve Yakoban
>Thanks. The two main cracks will be challenging to clean...
Bondo? Really? There's no issue with different expansion/contraction between the wood and filler causing problems?
David Yoho
>Since you're painting the wood anyway, why not fill the remaining crack with a mixture of fine sawdust and glue? Either yellow or liquid hide would work. Although I prefer to use hide glue on old furniture like yours, the fact that it'll be covered by paint gives you a choice.
David
Yep, Bondo or equivalent
>Any filler except solid wood will have different expansion rates than wood. If you put it in a crack that hasn't been stabilized the crack will continue to crack, as it would with any filler.
Bondo is popular as a filler because it cures fast, sands easily, and takes finish well. For clear work it can be tinted.
Ed
Orion/.Denton, TX
>Bondo is an absolute yes. It will expand and contract with wood and will fill very large voids if necessary. If you sand it level you won't see it beneath the paint.
Steve Yakoban
>I'm sold! Thanks guys!
