Spar Varnish Red oak Bubbles
Jeffrey D. Rose
>Hi Everybody,
I am appling some spar varnish to red oak that will encase a window. I am using the spar varnish because it will be exposed the a lot of sun light and possible moisture from time to time. I planed the oak, let it sit inside for two weeks and now I am putting the varnish on it. At all the open grain points there are bubbles popping up. What causes this and will it cause problems down the road if I sand these bubbles out and put another coat of spar varnish on?
TIA,
Jeff in Iowa.
