Dumb Google Sketchup question
Joe in a Cleveland suburb
>Hi folks.
I downloaded the subject program. Thought I'd play around with it a bit. For some reason my brain just does not grasp some of these drawing type programs.
Here's the question - I drew a rectangle. It's supposed to be a table top 32" long. I can't get it exactly 32". I can't stretch it. I can't seem to type in the size I want. How do I make what I drew an exact size?! What's the trick. I know it's staring me right in the face! What is it! Uhg!
It's the simple things that drive me nuts...
Thanks.
Joe
Re: Dumb Google Sketchup question
Carlos Clarke
>Draw the line. Make it any length.
Then before you do anything else go to the text box
in the lower right corner and type 32" and hit enter.
The line will become 32 inches.
I had a lot of problems 'getting' Sketchup until
I read more about their inference engine.
sawdustdan
>Joe
Select the rectangle tool then click and start pulling the triangle then just type the demensions eg. 32", 32" and hit return. You will see them in the lower right.
Dan
The tutorials are good
>Yuo know me, I've been using computers since I was a kid and use them more than any person should.
But when I first started using SketchUp I struggled..... CAD progams are a unique animal. Things that I thought should be easy..... well, took a bit to grasp. I found the online tutorials to be very helpful. After struggling with "How can I do this... it should be simple" for a few hours, I gave in and spent about 20 minutes going through the tutorial..... and there were lots of "OH, THAT'S IT" that followed.
Happy Woodworking!
if all else fails: RTFM
Joe Piotrowski - Chicago Burb's
>I will let you in on a software support acronym. RTFM. means Read The Fine Manual. Fine is a censored version on the most often used word.
I hate reading manuals but CAD/CAM and 3D Modeling software is usually not wiz bang and a few mouse clicks and you are done. many programs share similar features and commands. but training is required.
I need to spend some time with this as well. it's on my to do list but 15 minutes of poking around the help manual and tutorials showed me that it is not that bad.
keep at it, watch the tutorials, then let us know how it goes. you seam like a good benchmark. if you can go from struggling to cranking out drawings in a short time then I won't need to evaluate other solutions. and maybe other cad seeking woodworkers as well.
Time is too short for my hobbies as it is.
good luck.
P.S. I can send you all my hand sketches :)
Re: memory hog!
Ernie Miller
>I have spent part of the morning making a peice of peg board for a shop mock up and that stuff kills the memory. a 4X4 sheet just about does the machine in.
point of clarification
Robert Hutchins
>Howdy Joe,
You are not the first to struggle with something very elementary that SketchUp made arcane. DAMHIKT.
To set dimensions, immediately after releasing the mouse button when drawing a figure and before doing anything else, look in the window in the lower, right corner. You will see x,y coordinate lengths listed there. Use your numeric keypad to type in the values you want using a comma to separate them. Look first because IME which dimension comes first isn't obvious. I 'think' they always show the larger dimension first, but I've never read this anywhere - just guessing. You can do the same thing after using the push/pull tool to make your object 3D - type in the number after releasing the mouse button and before doing anything else.
You can also enter numbers as either decimal values, '4.25', or fractional values, '4 1/4' (note the space after the whole number, before the fractional part).
As others have said, go thru the tutorials. They are fun, easy, brief, and uncomplicated but they teach you the basics that you really need. One of the most useful things I learned was how to connect different parts of a drawing very precisely using the inference capabilities in SketchUp. Another useful feature is the ability to triple click the mouse to select an entire object. I use this a lot to select a component I want to move or connect to another component. You aren't likely to discover and connect this information to your actions without doing the tut's.
Please don't take this wrong, but don't be impatient and try to figure the software out intuitively (like I did). Many of the things are done very elegantly, but you have to pay the price of acquiring a bit of the plateau on the learning curve. Don't worry. It doesn't take long to use it.
HTH
JD in Memphis
>I don't see this VCB text box in the lower right corner. How do I enable it? I looked through the help and it's talked about a lot but they don't say how to turn it on and off.
JD
Carlos Clarke
>The VCB is at the right side of the status bar.
The status bar is the long gray rectangular area at the bottom of the drawing area.
The VCB looks like an indented rectangle.
Try drawing a line. It will then put a label in front
of the rectangle that says 'Length'.
It Puts a Different Tag Word Depending
Robert Hutchins
>on what type of object you draw. For a line it puts in "Length". For a box - "Dimensions". For a circle - "Radius". All this is based on Version 6.0.277.
>Thanks all. I get it now. See, this is why my 15 year old son calls me a knob...
Joe
