OT-- IE 7 Again
OT-- IE 7 Again
OT-- IE 7 Again
Nick Tuzzolino
>Somehow I upgraded to IE7. My Hew Packard Printer/scanner won't accept photos from the inserted card. Also I cannot scan. HP recommended a loooong, difficult procedure for me make everything compatible, but I am too illerate to try it.
Can I somehow easily undo the IE7 and go back to IE6?
Re: OT-- IE 7 Again
You bet
>START > Control Panel > Add/Remove Programs > Windows Internet Explore > Remove
THe trick is finding it, it's WAY down at the bottom of the list... most people look udner the I's for Internet Explorer or the M's for Microsoft Internet Explorer and don't down down to the W's.
Takes about 60 seconds to uninstall and it uninstalls nicely. FYI - alot of the older HP photo software has problems with IE7, in fact most software that has problems with IE7 are older version and the compniaes are trying to get you to upgrade to the newer versions of their software. IT took an month or two for QUickBooks to release a fix for their software.
Happy Woodworking!
Re: OT-- IE 7 Again
Re: OT-- IE 7 Again
Donald Pierson
>I had the same problem with my Epson combination unit...printer,copy,scanner. I went to Epson's website and downloaded and installed their new updated driver. Works fine now but it was a surprise when my scanner wouldn't work when it had been OK before.
Re: OT-- IE 7 Again
Re: You bet
Ernie Miller
>So if you uninstall IE 7 how do you reinstall IE6 if you don't have access to a browser? my new lap top came with 7 and I hate it. I haven't tried to print from my photo software yet? I hope that isn't going to be a problem.
Re: OT-- IE 7 Again
Re: OT-- IE 7 Again
Jesse in New Mexico
>I had a lot of problems with IE 7, too. Run time errors, awkward tab interface, etc. I wound up downloading Mozilla Firefox and all the problems went away. The tab interface is much easier, too!
Re: OT-- IE 7 Again
IE6 is still there
>When you install IE7, it doesn't remove IE6, just makes it inactive... presumably because they knew that tons of software may have problems talking to the internet with IE7.
Happy Woodworking!
Re: OT-- IE 7 Again
Re: IE6 is still there
Joe in a Cleveland suburb
>Ernie said his new laptop came with IE7. IE6 may not be there if it's a factory install of 7. I don't know, I never came across that.
I just bought my wife a little Dell laptop. I'll have to go see what's on it. I never paid attention.
Joe
Re: OT-- IE 7 Again
Ernie Miller
>even if it is factory new with IE7? that don't make any sense to me but?? who am I to question? would I be able to go yo start programs IE6 and enter it that way? or at least make sure it is there?
Re: OT-- IE 7 Again
Re: OT-- IE 7 Again
Jerry Nicholson
>I just helped a friend with his older HP computer running the original XP release with only 256mb RAM. Automatic Windows Update tried to install IE7 for him and thoroughly screwed up the machine. IE wouldn't start, everything was really slow, Norton Antivirus kept insisting that NAV be deleted and reinstalled. Trying to go back to a prior restoration point didn't help. I did a non destructive Windows XP recovery from the recovery area on the HD and then updated the system to Win XP SP2 (I replaced the 256mb RAM with 512mb before I did that). I specifically told the update NOT to install IE7 and not to try it again. I also turned off Automatic Windows Update and told him that when he does a manual Windows Update to be sure to uncheck any attempts to install IE7. I installed Firefox 2.0 and suggested that he use it rather than IE. His current subscription to NAV was about to run out so I replaced it with Kaspersky AV. Everything works a lot better now but you can be that I am not going to install IE7 on any of my computers.
Jerry
Re: OT-- IE 7 Again
BINGO
Nick Tuzzolino
>It's Amazing when you know what you are doing. THANKS, Mark. You saved me a ton of grief. Just a side note, a few years back (on the Pond) you sent me a plan for your home made Vari-grind jig. I'm still using it, naturally, and I thank you again for that, too.
Re: OT-- IE 7 Again
You Betch 'Um, Red Ryder ! *LINK*
Robert Hutchins
>It's called FIREFOX ! ! !
Download Firefox
Re: OT-- IE 7 Again
I *think* so........
>You're right.... I have not tried uninstalling IE7 on a new PC yet. Haven't had a need. Only had to on older PC's that have older software that is incompatible with IE7. Most new software is compatible, it's only software that is a little older, that presumably wouldn't be on your new laptop to begin with.
Happy Woodworking!
Re: OT-- IE 7 Again
IE7 vs IE6
>Don't quote me on this... I'm not entirely sure. But IE6 was "built-into" WindowsXP..... that was part of the whole lawsuit, it's the OS not a browser. IE7 installs like an application.
So just like Adobe, or QuickBooks or many other pieces of software, when you install one version it doesn't undo the original, it just places the second version along side and makes it the default version of that particular program, but the original is often still there. Not all software works liek that but alot does. Of course to negate what I've just said they're just as much software that overwrites the previous version when you install a new version.
But as far as IE7 goes, IF it lets you uninstall, then it's smart enough to have something else (IE6) waiting in it's place. Can't prvoe it, but it's an educated guess. But Vista???? I need to do some homework on this particular question.
Man, things change too quickly :)
Happy Woodworking!
Happy Woodworking!
Re: OT-- IE 7 Again
Re: OT-- IE 7 Again
Dan Donaldson
>For tabs, get the tab mix plus extension if you haven't already. It makes the tabs work like a champ. The default tabs in FF are OK, but the extension gives you a lot more control over how they work.
Re: OT-- IE 7 Again
Boring
Bill Howatt
>I upgraded 2 XP Pro, 2 XP Home and 1 Toshiba laptop to IE7 and the whole process was boringly simple. Everything works apart from last year's tax program on 1 machine but that's just part of upgrade life. As far as being different, well, I thought it looked the same apart from some minor things and the tabs - a bit handy but nothing as thrilling as I thought they would be.
Bill
Re: OT-- IE 7 Again
Double welcome!
Re: OT-- IE 7 Again
Use Windows Explorer to get
Dustmaker Mike
>the IE V6. Open up Windows Explorer and tyep in a URL. WWW.microsoft.com and it will take you to the site. Or you can download Netscape before removeing IE7 and browse the Internet to MS either way will get you there.
Re: OT-- IE 7 Again
Used to be...
Jason Roehl in Mulberry, IN
>...that you could only use IE to download software from Macroslop. I don't know if that is still true, as I just automatically use IE to go there when I need something from Macrobloat.
Jason
Re: OT-- IE 7 Again
Still True. Only Reason I Keep IE on My Machine
Robert Hutchins
