Nedd Ideas to extend desk legs
Bart Goldberg
bart goldberg
>Morning all,
I need some advice. I need to extend the desk legs of the desk I made my son several years ago. He's now grown quite a bit and can no longer fit his legs under his desk.
The desk legs are about 1 3/4" square cherry (stained and poly'ed), and need to be extended about 4-5".
I was considering getting some ebony or wenge, and attaching them to the bottom of the legs. Of course the problem is how to attach them.
I was thinking that a set of two dowels would work okay (to keep the add on pieces from twisting), assuming that I can drill perfectly straight
holes into the desk legs (that may be a bit tricky with a free hand drill. I could over size the holes and use epoxy to cement in the dowels/leg ends,
so that if the holes are slighty off, the add-on pieces would still fit flush with the legs.
I was also thinking to use slightly wider pieces as add-on, then plane/scrape/sand them till the were flush with the existing legs.
I'm always lookign for a better/easier way to do things - any suggestions here?
Thanks
Bart
P.S. remove the 2 to reply by mail
Re: Nedd Ideas to extend desk legs
Rick W
>I think your idea of using two dowels would work fine.
To disguise the joint, you might use a small bead molding(1/4" or so) all around the leg at or below the joint.
You could also make the extension piece about 1/4" to 1/2" larger than the existing leg and taper it downward.You could round the top with a 1/4" radius to meet the existing leg.
Just some ideas.
Rick W
>Good Morning Bart,
I like Rick's idea about celebrating the joint where the extension meets the bottom of the leg. You could use epoxied threaded stock which may be stronger than a wood dowel. I'd use cherry for the extension. If the lengthened legs don't look right, then you could always ebonize the cherry extensions.
George
Charles Sharp
>A photo would help a lot.
How about making a sleve out of 4 pieces mitered together with a rabbit for the leg to fit into?
>Pretend you're an orthopedic surgeon fixing a broken leg; epoxy a length of 1/2" threaded titanium rod into sloppy holes across the joint. Steel rod is OK if you don't have any titanium.
Clint
Lee Gordon
Lee Gordon
>Since your'e thinking of using a contrasting wood for the leg extensions, how about using something like a bridle joint? It would give you plenty of glue surface, and you would have either a tongue of darker wood surrounded by lighter wood or a tongue of lighter wood inside the darker wood, depending upon which combination you felt would be more attractive.
>I sort of like the idea of putting an all thread rod in each leg and bolting the add on piece on. You can make a through hole and just put a nut on the end (in a suitable hollow of course). Then as others have said, celebrate the joint with a decorative molding.
I wouldn't make a big deal out of it.
Don Henthorn
>THe pressure will mostly be down with very little side leverage to worry about. I would use a 5/8" to 3/4" dowel and over sized add on pieces and work them down to size. A larger dowel if it is a good fit and glued is not going to twist or go anywhere.
Re: Need to extend desk legs - radical idea
Carol from AZ
>Make him a new desk?
Dan Donaldson
>How about cutting the legs off at the top (as high as possible) and then making new ones that are the right length. To me, this would look a lot better than any "fix" I could come up with to lengthen them. That way, you could make the correct taper for the length, and you would have the full size to fasten the new part on.
