Plywood Joints - Range Hood
Doug Reynolds in Seattle
>Earlier I posted about making a range vent hood over a kitchen island. If I make it out of plywood what are the best joints for the portion of the hood that is sloping up to the ceiling with the lower rectangular box section? Since this will be concealing the filter/fan/light unit, it has to support some weight without joint failure. Was thinking of using a 22 1/2 degree lock miter bit making the slope at 45 degrees. The CMT bit is close to $200 so, is there a better and cheaper way?
