A55 Smoothing Plane
making your own plinth blocks
Steve Silca
>Has anyone here made their own/have a plan for making their own plinth blocks. I am restoring certain parts of a 2-flat in Chicago and need about 30 plinth blocks that are roughly 10 1/2" tall and 4 1/2" wide. I'd hate to drop a couple hundred dollars at a home center if I can make them myself out of 2x material. Any ideas?
SS
Re: making your own plinth blocks
Keith Newton
>I have done them by using a molding head on a table-saw, although I think if I needed to now, I would try it with a router. There are some molding cutters that should do a good job.
I was just looking in Lee Valley catalog, and something like 16J54.52 would give a nice touch. You may need to use a nice even textured wood, and even then, you may need to climb-cut if you get much tear-out.
If you have never climb-cut before, don't without asking for advice first.
Bill Earl
>I made about 40 pairs of plinths for my renovation project. I did most of them in poplar. I also did some in cherry, maple and mahogany.
Material choice depends partly on the finish. You can use a lesser wood if the final finish will be painted. Nevertheless, I would hesitate to use construction-grade 2x stock. Much of what you find in the home centers these days is not well dried and will shrink on you. It is also very soft and will quickly show dings and dents. Plinth blocks in door frames are particularly vulnerable to kicks or vacuum cleaners being dragged from room-to-room.
Poplar is a good choice for paint-grade work. It doesn't look all that bad with a clear finish either. It machines well and is substantially harder than pine.
Hal Smith
>I've made some on my router table using maple. Didn't have a problem with tear out. But be careful with a climb cut. Keith is right. It can get away from you in a hurry.
NickB
>I've made I don't know how many plinth blocks and rosettes for my current remodeling project. I've used poplar (everything is paint-grade), although there are some high traffic areas where I wish I had used hard maple for the plinth blocks. They're easy to make with a router table and fence set up. If you have a victorian, you can get a rosette cutter to use on your drill press too.
For blocks that are 10.5" tall, you'll want to think about making them 'vertical grain' (so the grain runs up and down, as opposed to side to side, when looking at the block). If you do that, you need to make them over-width, then cut them to size after you route the profile (so you can cut off the blow out at the end of the router pass).
If you meant dimensional lumber when you said 2x material, I'd avoid that. As a previous poster said, even KD dimensional lumber is to wet for trim use, and it is really, really soft (next time you're at the lumber yard, count how many growth rings you can see in the end of a 2x4-it's not that many).
Hope this helps,
Nick
