Squaring a square question?
>Has anyone tried to square a framing square?
I have a Stainless Steel framing square I bought new thirty years ago. It ahs been one of my treasures until yesterday. I was trying to use it to be sure some panels I was cutting were square and discovered it is no longer square.
First: Don�t you check them by using a wide piece of say MDF with a straight edge and drawing a line across with the long leg of the square to the left and then checking to see if it reads square with the leg flipped to the right? That is, reverse the square and see if it reads true both ways?
Mine reads slightly �closed�. That is, slightly less than 90 degrees. I have another steel square and it reads slightly open.
So, what else do I need to know about testing them for square and ahs anyone tried to correct one? I saw an article somewhere about �peening� them on an anvil with a ball peen hammer or a punch.
