Re: Wood Expandometer on the cheap
Dave Mount, -27 F this morning
>Barry--
This is too late to help you, but it reminds me of a tip I saw somewhere about making a shop gauge to assess humidity/expansion/contraction in the shop. Next time you glue up a wide panel (the wider the better, 24" or more), save a trimming off the end (just an inch wide is fine). Measure it's length (width in it's original orientation) and record it along with the time of year and any other info relevant to the current conditions. Then, over time, measure it at other times, making the same notations. Over time, this provides a point of reference to the effect of recent shop conditions on wood moisture content. It's not an absolute measurement, but gives relative information. When you're facing a decision like your current one, measure your index stick and consider it in the context of the overall variation you've seen.
Of course, this assumes that the wood you are using is well acclimated to the same conditions that your index stick is. Also, the index stick, being narrow and with massive endgrain exposure, will respond to changes in humidity somewhat faster than lumber will. I suppose you could slow this down a little by putting a very light coat of finish on your index stick.
I had one of these for a time, and it was interesting to watch. Eventually I broke down and bought a hygrometer for the shop. I have a moisture meter too, but the hygrometer tells me most of what I need to know. The shop humidity flucuates seasonally, but is pretty stable day to day.
Best,
Dave, -27 F this morning, -49 wind chill
