Rough and Ready (Lots of pics!)
Alan Young
>Today I delivered the benches see on the recent "WC Sightings" photo.
These accompanied a table I delivered a month or so ago.
A very different type of project for me-the wood (oak)was supplied by the client who expressly required the buzz saw marks to be left on the working surfaces where ever possible. This made the joints in the benches and the table a challenge. I did plane mating surfaces so nearly all joints were tight and flat.
The base was built with mortise and tenon joinery were the aprons joined the legs. I added cross beams and glue blocks. And I also lag screwed plates to the legs in a fashion seen when the legs are meant to be disassembled. This table is not to be taken apart but I wanted the extra construction techniques the re-enforce the joinery. (The leg plates are not yet attached in the lower photo)
The top is a two part lamination-each layer aprox 3/4 think. The lower layer was planed flat on both sides and jointed and glued up as a normal top.
I jointed the edges of the upper layer and planed it's underside only-leaving the top with the buzz cut markings. Because the top surface is not planed flat, the joining edges have a ridge here and there. In the higher places I slightly evened off the mating surfaces with a carving gouge.
Then I glued the two layers together
Here is the top with a fresh coat of finish (Five coats of Polyurethane)
The Bench design features a sturdy "I beam" that is attached via mortise and tenon into double faced leg brackets.
Pocket screws attached the base to the top, then the outer brackets were glued to the inner brackets. I kept the grain of the leg brackets and the bench top oriented in the same direction so gluing and screwing them together should have no movement issues.
Here are some shots of the finished pieces
The watch and double AA battery give some perspective to the
buzz saw marks..
The table is 60" L 42" w and 30" high. The benches are 44" L 18"h and 14"w.
I believe I'll be making a trestle table and a set of benches for the clients brother. It the trestle table will be be treated the same fashion...
I look forward to taking on another project of this type.
Thanks for looking.
Alan
