How do you cut your sheet goods?
Lee Beeden
>I have a table saw with a 29" rip fence and have found that this is not enough. For those of you without the luxury of a sliding table what creative solutions have you come up with?
many thanks
Lee
Re: How do you cut your sheet goods?
Festool TS 55
>Perhaps not the cheapest solution but I recently purchased a Festool TS 55 Circular saw with guide rail to cut sheet goods. So far I have been very pleased with both the performance of the saw but with the accurate cutting I can do with it. I have a small shop and no room for a slider. This has been a good alternative for me.
Tom
Johanna
>I am just finishing cabinet work for my home office -- 9 cabinets and 3 desk tops. I took the 3/4" plywood to a cabinet shop and paid them $50 to cut it to my specs. I gave them a cut list and layout sheets. Best $50 I've spent in a LONG time!
I cut the 1/2" baltic birch sheets myself on my table saw since they are so much smaller and lighter.
On those occasions where I have cut up sheet goods, I have done it with a circular saw (or a saber saw on 1/4" stuff) using a straight-edge guide.
Re: Festool TS 55
Jesse in New Mexico
>Oh Tommy, you've started down the slippery slope. Try a Festool sander and there's no turning back!!
Yes, the TS55 is great for cutting sheet goods. I bought mine thinking I would use it to break down the sheets into manageable pieces and then do the finish cuts on the table saw, but its so accurate, no need for the table saw.
I just back up the truck to the gashop's door and slide a piece of ply or mdf onto waiting sawhorses (with a sacrificial sheet of ply on top), never have to actually lift the sheet.
And with Festool dust collection, I can break down half a dozen sheets and have maybe a tablespoon of dust on the floor!!
Garrett in Victoria BC
>Circular saw with a Freud 1/16" finishing blade and a 100" Clamp 'n Guide. I made a simple 2x4 ladder frame about 30"x72" that hangs on the garage wall. When needed, I lay it on the floor, and flop the panel onto it, mark my lines including off-set for the saw base, clamp, set the blade to about 1 1/4", and cut through the panel and into the supporting 2x4's. Always place the clamp on the finished piece rather than on the waste just in case.
Cheers, Garrett
At the store
Felix B
>Since I don't have a truck to bring home 4' x 8' sheet of plywood, I cut them to the size + 1" where I buy them. At home - the largest size I dealt with - 2' x 2' panels; they are cut to the exact size using table saw and a sled.
Cheers,
Felix
p.s. I wish I had a panel saw for these types of cuts...
Several ways
Lee Schierer, McKean, PA
>When I can't cut the piece I need using the table saw, I use a clamp on straight edge and either my skill saw with a 40 tooth blade or my Bosch Jig saw with a progessor blade without the orbital action. Sometimes I clean up the cut on my TS, once the piece is free from teh full sheet.
Lee
Very Slippery
>I've heard lots of good comments about the sander. But I have my eye on the 12v C12 drill/driver. With the offset drive head additions it looks like something I would love using in the shop. I'm tired of trying to do furniture work with my heavy Dewalt that's better suited for carpentry.
T.
Bob Dodge
>Lee,
Generally when I buy sheet-goods, I already have a cutting-plan drawn-up. Rather than struggle with 8' or 12' sheets, I'll generally take advantage of my supplier's panel-saw. Usually a big HolZher or the like. They charge $1./ cut, and guarantee no edge-chipping (Melamine), and a tolerance of 1/128" over an 8' length. I'll break the sheets down into more manageable sizes for transport. Saves a lot of time and hassle.
At home, I'll break them down further on the table-saw. I do have a small Exactor sliding-table on my UniSaw, but seldom need to use it.
Bob
Not to start another thread, but...
Felix B
Ok, ok... can I say: sander is a sander... ? I use Bosch 5" ROS and hooking it up to DC leaves or throws no dust at all.
Please expand.
Thanks,
F.
Re: Very Slippery
Jay St. Peter - Southern MD
>I have the TDK version of the drill/driver. The attachments are real nice. I don't know how I lived without a right angle and offset attachment for as long as I did. The C12 form factor looks pretty cool.
Jay St. Peter
Re: Festool TS 55
>I have the older version of the saw. But, before I got it I used a straight edge to guide a regular circular saw to break down the panels. Back then, I cut slightly oversized and followed up with the TS for final cuts. Now I can cut straight to final size. The best part of the Festool saw is the DC. I almost always use it for MDF as it puts off far less dust than my table saw.
Jay St. Peter
Re: sander is a sander...
>I wish a sander is a sander, a saw is a saw, etc. I would've spent much less on my shop over the years.
Compared the the PC333VS I have, the Festool sander is much smoother running and quieter. The PC makes my fingers numb and eventually hurts my wrist (that already has problems from repetitive stress). I can run the Festool all day without a problem. Hooked to a shop vac, the PC was pretty good with DC. The Festool is better. Just being able to run it all day without buzzing hands, earplugs, or dust masks makes it worth the money for me.
It's sorta like moving from a $50 Craftsman jig saw to a Bosch ... not in the same league.
Jay St. Peter
Bill Howatt
>I usually try to get at least one cut done at the store with a 4x8 sheet to make life hernia-free.
I made an open "ladder-like" table with folding metal legs that I keep out in the garage. I put the sheet on it and use a guide with circular saw to cut the panel to size. The table is sacrificial and has all sorts of cuts on it now. I made sure the screws were at least 1-1/4 below top surface. I often cut slightly larger and finish on TS but have found for a lot of things it is possible to cut exactly to size.
I made a guide for my circular saw by screwing some aluminum angle onto a piece of ply the desired length. I then put the saw on the ply against the angle and trimmed the guide which provides and edge exactly where the blade cuts. This way I can put the guide down on my marks and don't have to worry about blade thickness or saw shoe offset. Be sure you have the guide on the desired piece not the waste or it will be out by the blade thickness - this is one reason that cutting it about 1/2" oversize and then trimming it on TS is a good idea just in case you foul up!
Bill
Falberg saw Co
>The correct answer would be : RotoZip, with a straight edge.
Larry Clinton At Frankfort (Central)., Indiana
>Today I cut them on my Unisaw with the 52" Bies fence. Before I got it, I used to use a straight edge (jointed 2X4 or other handy straight item) clamped to the plywood, with a circular saw & hollow ground planer blade. I did make a sub-base for my circ saw from 1/4" hardboard and used double back tape to attach. This gave me a pretty good finish cut with no or very little tearout.
Circular saw and garbage cans.
Rod Peterson -- Ormond Beach
>Works best if the garbage cans are plastic…
I have a variety of things I've used for a straight edge—Tru-Grip Clamp 'n Guide (like Garrett, but I don't have one as long—say clamp), a Werner wallpaper straight edge I acquired somehow years ago, a two-piece purpose made cutting guide.
The Werner is only about seven feet long, so it obviously is not used on the eight foot length of plywood—that's what the last one above is used for.
For saws, I either use my SawBoss (Porter-Cable 345) or my Trim Saw (Porter-Cable 314) depending on which mood strikes. Like the others, I generally cut oversize and then finish up on the Unisaw.
The garbage cans (two for a 4x8 sheet) are great support, because they have a fairly wide stance, are a comfortable height (the 32 gallon variety), and, if you follow the advice in the first paragraph, you don't have to worry about depth of cut.
Rod
Re: Not to start another thread, but...
Jesse in New Mexico
>Hey Felix,
What Jay said, plus a couple of other things I really like: there is no static electricity (antistatic hose) like on a shop vac, so no shocks whenever you touch the vac; the paper is great - doesn't load, extra holes improve dc; both the sander and the vac have speed control; some of the sanders (ROTEX) have dual mode as very agressive orbit or gentle orbit; the vac comes on automatically when I turn on the sander and stays on 10 secs after the sander is off to get those last few bits of dust, the vac has bags that seal easily so you are not emptying the vac into a trash can and making a cloud of dust.
Also, if you use the saw, too, everything is already there and set up, just swap the electric plug and the hose.
a different approach
Tom Stockton
>Depends wether you ripping or cross cutting.
I still use this sequence for breaking down sheet goods even though I have a slider.
1. rip panels to width + 1/2"
2. rip to exact width, if the edge from step 1 is good this will be one cut if it is a little wavy I will rip both edges. this leaves the panel a managable size. when you rip start with the widest rip and work your way down. if I'm cutting 4 pieces 11" wide a lot of times I will split the panel in half first.
3. crosscut using a shop built sled. In my old shop we had a Biesmeyer sled it was nice but a shop built one is just as good and you can make a couple of different ones of various sizes.
For long pieces I made a support that the piece would ride on, it was about 6' long and was parralel to the blade and sat 2 or 3' from the edge of the saw and level with the top. looked kinda like a long sawhorse.
With your saw can easily rip to the center of a panel. so if you need a piece 35" wide rip the ply at 12 7/8" or so and you will end up with a 35" panel. The reason I'm vague on the number is because I get panels that aren't always 48" wide.
I still have my wife help me rip panels if they are heavy or the cuts a real critical.
All this said the festool is a great set up for this and it is what it excells at. Fine homebuilding did a review of rip rail systems and they liked the festool and another one.
Tom
Voompah, Voompha, Voompah
Noah
Lee Gordon
Right!
Lee Gordon
. . . now, how big is a cubit?
Angus Barclay, in New Zealand
Glenn Madsen near San Francisco
>This sounds a lot like what I do, except for the 'flop it on the floor' part. I don't get up and down as well as other folks. Well, the 'down' is OK. The 'up' is sometimes a challenge. ;)
The 2x4 frame goes on sawhorses or workstands, whenever possible.
My table saw has a wide enough reach for some things, with the 50" fence to one side. It doesn't slide out of the shop too well, though, when I'm crosscutting some pieces, and those take some headscratching. (No, I don't _need_ another tool right now. Really.)
Re: No smiley face?
>Not with MY Rotozip. At least not on my sheet goods. That sucker would die in 5 minutes, even with a new bit/cutter. Sheet rock, maybe.
3 ways
>On the store's panel saw (if I'm patient and drove the car or golfcart)
With my PC 7.25" circular saw in the driveway (if I was impatient at the store and drove the van or brought the trailer).
With my tablesaw (only to trim up accurately after either #1 or #2 above).
Happy Woodworking!
