>A question on cypress somewhere else got me to thinking...
A friend and I are planning a trip to Florida in March. We will have room to bring home a bit of wood if I choose. I know cypress is great for outdoor projects, but I really don't have much need for that. I am just thinking about building some small projects for gifts, etc. Is cypress. How is cypress for appearance, workability, etc. Anything special?
>I live in Fla. and have made many projects of Cypress-- shelves, cabinets etc. It is a nice wood to work with. A bit dusty when machined. Has nice graining and finishes real well.
>Flatsawn cypress has a tendency to flake; that is, the wood may separate at the summer wood line, producing a loose "cathedral" that is sharp as knife. I always made it a point to use quartered or riftsawn wood.
Choose your boards carefully and keep an eye out for signs of flaking and/or surface checking.
I brought back a carload of cypress from Lousiana and made some nice outdoor chairs and a table. I would only add to what the others have said and that it is soft - much like pine. But otherwise, it is nice to work with with no real problems. My hardwood supplier is stocking a much harder "cypress" said to be from Australia. It is very attractive and was available as flooring. And then there is "sinker" cypress from the "knees" of cypress trees. And that exhausts my knowledge of cypress. 8-)
>I've used a bit of cypress. It works very easily and smells great when you cut it. The front door I built (in the "Articles" department) was made from cypress. Without a stain, it has a very nice light blonde color to it. It is fairly soft.
The used machinery place here in Lake Wales, of all places, has tons of cypress that has been air drying for years and is stacked and stickered very well inside a huge warehouse. Can't recall the price, but it was inexpensive; cash gets ou a better deal as does buying a big quantity. All sorts of thicknesses and some really wide boards.
>Jim, You may want to check into the sinker cypress. Cypress is one of the most rot resistant woods, and since it grows in river-bottoms, it often had its roots undermined by meandering channels, or was blown down in storms, over the centuries. Since rot needs air to live, this submerged wood is preserved as long as it is there.
After being it the rivers and lakes for many years, they become waterlogged, and sink. Sinker cypress is cut from logs that have been pulled from the bottom of some of these locations and sawn into lumber.
If you are buying second growth cypress, I would like to point out that you really need to be careful not to use sapwood for anything needing decay resistance. I also believe I have read that the second growth heartwood is not as resistant to decay as old-growth.
Well, they say a picture is worth a thousand words and your pic really does justice to the nice grain that cypress can have - and as I remember it. Very nice chest of drawers as well. Thanks for posting your work.
>You asked about using cypress for turning and I can give you only limited info. I am in California where we have monterey cypress growing along the coast. I suspect it is similar and vastly diferent at the same time. I was chating with a bowl turner at the last show and asked if he ever worked with Cypress. A scowel imidiately came across his fase as he said he had an almost 100% failure rate with cypress. He turns green and lets the blank dry and he said so many of his cypress blanks crack during the drying process that he does'nt even bother with it any more. My own experiance has been exactly oposite and the more I turn it the more I like it, however I turn %100 dry wood and usually spindle work for furniture.
If you are traveling to Florida I would like to sugest that you also look into getting some Melaleuca quinquenervia, or paper bark. It is an invasive tree that is putting the cypress forests at risk because it tends to choke out the cypress trees and is also extrelemy volitile in a forest fire. Melaleuca quinquenervia has also been planted in California as an ornimental. I got interested in it after seeing a chair a friend of mine made from it. At first glance I thought it was black acacia. Melaleuca quinquenervia looks like a eucalyptus but is actually in the myrtle family and even has a slight camphor like scent. Some people have skin sensitivities and respritore precautions should be taken.
>They have been trying to eradicate that spcies down here. That's the first I've heard of its use as lumber. Should be easy and probably free to get some boles of that for milling and drying. Do you have any idea of its behavior during drying? Stability after dried?
>Like all the other myrle related trees it has a marked prefrence for movement. and end checking. both can be minimized by carful prep and storage. The bigest conceren can be for skin and respritory sensitivity.
