OT Electrical Outlet Grounding Question
Jim Rahbe, Bedford, TX
>All,
My daughter has an older house where most all of the outlets have only two connections, Hot and Neutral, but no Ground. We are doing some remodeling and as we do would like to upgrade to the standard three connection outlets. Obviously I could run new wires all the way back to the circuit breaker panel, but is there a better way?
Could I simply run a single solid conductor from the panel and connect to the ground connection on the outlet?
If I were to do two rooms, each with their own circuit breaker, would I have to run two separate conductors back to the CB panel or could I tie them together at the rooms and just run a single conductor back to the panel?
Right now I�m just in the planning stages and will check with the city for local codes, but it would be nice to know if the basic plan is generally acceptable or not before contacting them.
Any input would be appreciated,
Jim R.
