OT: MS Excel help needed
Luke Herzberg
>Howdy folks, how can I use the name of a worksheet tab in a cell elsewhere? For example, I make a macro to add another worksheet tab and also create a new line in a summary worksheet. If I name the new worksheet "Febuary" how can I look at the name of that worksheet, and display its name in a cell on the new line in the summary sheet?
Thanks,
Luke
Re: OT: MS Excel help needed
Dan Donaldson
>There is probably a way, but need a bit more info on exactly what you need to do.
Re: OT: MS Excel help needed *LINK*
wilbur
>I think this page will help you with what you're looking to do.
Variable worksheet names in Excel
Craig P
>Look into asap utilities - quite useful & free, though from your post may not be exactly what you're looking for. Something similar that I needed at one point was the vba snippet:
Function lsheetname(Optional sheet_num As Long) As String
If sheet_num < 0 Then
MsgBox "Value must either be blank or positive integer"
Exit Function
Else: If sheet_num = 0 Then sheet_num = ActiveWorkbook.Worksheets.Count
End If
lsheetname = ActiveWorkbook.Worksheets(sheet_num).Name
End Function
In any cell can put the the following:'
=lsheetname()
and the name of the last sheet will be returned. Else
=lsheetname(2)
will return the name of the second sheet, etc.
asap-utilities.com
Thanks, that did it!
Luke Herzberg
>I guess a better explanation of what I needed was how to extract filenames, and then the worksheet name from within that.
Whatever it's called, it did what I needed.
Thanks,
Luke
