CUTTING BOARD MISHAP
CARL BARTON
>I recently made a cutting board for my wife using the guidelines from the recened WOOD magazine. All went well until the following morning when I went to check on the project. Everything appeared to be lined up when I glued the three sections together, as per the instructions in the magaizine. But when I took a look at the cutting board the following morning the ends of the baord had curled up, leaving the board with a slight bow.
The only things I can think of is maybe I clamped the three sections to tight, which cause the board to bow like it did, or since it turned very cold over night the cold effected the drying proccess of the glue.
Any suggestion in what I did wrong? I think I should be able to take the bow out of the board and still leave me with a pretty good cutting board.
Carl
