How can I safely make a 1/4 round moulding piece
arw01
>I need to make 4 pieces about 18" long of a corner round moulding, that would be 3/8" wide on the wide side.
My tablesaw 45 is not in alignment, and a piece this small would get hung up in the throat plate because of the blade tilt width of opening.
I do have a chamfer router bit from a set. From memory I recall a fellow that made a block that trapped the work piece between this block and the bit to make small pieces.
Thanks
Alan
