Pipe Clamp tip.
Pipe Clamp tip.
Pipe Clamp tip.
>I have a bunch of different pipe clamps. WoodSmith just had a tip about adding wooden jaw Inserts. Pieces of wood that had a hole for the pipe that covered the jaws. Good Idea.
Better Idea. Or perhaps a tip on a tip.
Drill a hole through the scraps or perhaps half inch plywood and make the covers for the jaws, but make them so that the clamps will sit on them and not fall over. Some of my clamps have little feet and some don't. I could add these loose jaw pads and "standardize" my clamps so that they will sit up, the handles will clear the table and I can spin it. The top of the jaw pads could serve the same purpose if the clamps were turned over, so that the pipe was "up". Might stick the pads to the jaws with double stick tape or glue them.
Re: Pipe Clamp tip.
I Prefer The Double Stick Tape
Re: Pipe Clamp tip.
Re: Pipe Clamp tip.
Keith Newton
>I use thick leather glued to mine with spray contact cement.
