Gluin & Screwin...
Bri in Mtl
>If you want to reinforce a glued up joint with a screw(s)/dowels would you apply the screw during the glue up or after the glue has dried/cured?
I'm wondering if by applying a screw after a glueup one would be applying tension to the joint more than just simply reinforcing the joint.
