Shop insulation question
Phil Joines Krum Texas
>I'm thinking about puting foil covered foam board on the top of the ceiling joists in the shop and adding bats and sheetrock latter when I have the cash.
The foil is suposed to reflect the heat and the foam boards will keep the heat from escaping now.
Would adding standard FG bats cause a problem with trapped moisture?
