NEW Shop Shots!
NEW Shop Shots!
NEW Shop Shots!
David Yoho
>Our four newest Shop Shots are up!
Our first submissions for this year are a delicious mix of inspiring projects by several "regulars" and one newcomer. Stop by Shop Shots and see what these craftsmen are doing.
David Yoho
Editor - Shop Shots
NEW Shop Shots!
Re: NEW Shop Shots!
John Richards
Dean Lapinel
>All very nice looking. Sharp looking rocker John. One concern of mine has been that front leg joinery. I've been looking for methods that avoid the screws but I'm concerned about depending on lateral forces with just glue as you have.
As an engineer you must have made that decision on a sound basis...would you discuss this?
Dean
Re: NEW Shop Shots!
Dean ...
Mike Farinella
>I case you don't already know, you can click on John's mame in the Shop Shots page and email him directly.
Re: NEW Shop Shots!
Re: John Richards
JSRWoodworking
>In the front leg jointery the screws really add no strength at all to that joint. A stainless screw epoxied into the front leg intersection as some folks do gives you essentially a very small metal pin in that intersection. Since the adheasive surface area is so small you get very little added strength. Screws have very little purchase in the wood. I've got 100% confidence in that intersection without screws.
I've actually done a rocker drop test from nearly 4 ft off the ground on an angle (worst possible angle I could come up with) and the only part that failed in the chair was the grain in the seat. The grain in the seat split slightly, but all intersections survived the drop with no damage.
If any of you are intersted in maloof style woodworking I'd encourage you to join my woodworking school forum at http://www.jsrwoodworking.com/forum/YaBB.pl I give lots of info and plan on using it as a tool to aid my students and any other potential students out there in the maloof style of chair making.
Thanks,
John
Re: NEW Shop Shots!
Re: Dean ...
Dean Lapinel
>Thanks mike,
I do know that but I thought this would make for a good public discussion.
Dean
